ᐅ Moss and dirt on reddish bricks – cleaning
Created on: 12 May 2016 10:38
U
Umbau-Susi
Umbau-Susi12 May 2016 10:38
Hello knowledgeable ones,
During our summer renovation, we noticed that the reddish bricks in our yard are covered with moss and dirt.
So now my question is: how would you approach cleaning them, and especially what tools and, if necessary, chemicals would you recommend? Should any protective treatment be applied afterward?
asks Sylvia
12 May 2016 11:04
I assume you mean concrete blocks that are colored red on the surface?
Umbau-Susi12 May 2016 11:35
Paved terrace made of square concrete pavers, left measuring rod visible, wooden edge at the bottom
I assume these are concrete pavers colored red on the surface?
These are the pavers, but they usually have a much more distinct red tone. That’s the color we want to restore ;-)
U
user-d29
12 May 2016 11:59
Use a chemical cleaner first, then apply a moss and algae remover and scrub thoroughly.
For a less chemical approach, use warm soda solution and scrub thoroughly.
However, I believe your stones are bleached. The red tone will gradually fade...
12 May 2016 14:50
I think so too. The concrete pavers will only be colored on the top 2 cm (approximately 1 inch) – the color will eventually fade over time.
Moss usually looks a bit different 😎
If you have green growth, spray it with an algae remover and treat/clean it according to the instructions.
I wouldn’t use a pressure washer on these stones, as it can make the surface even more porous than it already is.
How old is the paving?
Umbau-Susi12 May 2016 15:16
We are not sure about that. We will probably try it with Algenex. Thank you.
