We want to install a natural stone-covered entrance platform for our single-family house. It is basically just one step, approximately 2.40 x 1.20 m (7 ft 10 in x 3 ft 11 in) in size. For the material, I chose 60 x 60 cm (24 x 24 inches) flamed basalt slabs.
The platform was poured from screed several months ago. It slopes downward away from the house, so rainwater can drain off.
The question now is, do I still need a drainage system for this? The tiler says no, but a civil engineer friend says yes. If the slabs are properly glued, how could they freeze and be damaged? What benefit would a drainage system actually provide? Water would never penetrate that deep anyway.
If there is a risk that water can penetrate through the joints between the panels and the screed, this can already cause damage during freezing conditions. In the worst case, the panels could come loose.
Masipulami schrieb:
If there is a risk that water can penetrate through the joints between the boards and the screed, this can cause damage during freezing temperatures. In the worst case, the boards could come loose. However, if water is getting through the joints, then there is something wrong with the joint itself.
Sebastian7913 Apr 2016 13:42Why? Joints are not necessarily waterproof – and how would you even notice? If it's too late, it's too late – so make sure to seal properly beforehand or provide adequate drainage.
Sebastian7913 Apr 2016 14:31Yep, there are heated drainage channels for that.
I personally prefer covered solutions, so you have (almost) no problems.
