derhoeppi13 Nov 2012 19:38Hello dear community,
I would like to ask you a question and hope for reliable answers. Our house is currently under construction and has two relatively wide windows. The widths are 2.8 m (9 feet 2 inches) and 3.03 m (9 feet 11 inches). These windows will be fitted with exterior granite window sills in Rosa Beta. The thickness of the window sill is 3 cm (1¼ inches) and the depth is 25 cm (10 inches).
Now my question to you is: Is it possible to have single-piece window sills under these conditions, or is it necessary or advisable to install two window sills per window at these widths?
Regards
derhoeppi
Regards
derhoeppi
Häuslebauer4013 Nov 2012 20:23I believe I have the same material at both of my terrace exits, which are just as wide or even wider. Therefore, it is definitely possible to get the window sills in one piece, since they are like that for me as well 🙂
Bauexperte14 Nov 2012 09:21Hello,
Kind regards
derhoeppi schrieb:Natural stone/marble/granite is available in all conceivable thicknesses and lengths; as always, it is simply a matter of cost. Whether a window sill is split or installed as one piece makes no significant difference and has no notable advantages or disadvantages. 🙂
Our house is currently under construction and has two relatively wide windows. The widths are 2.8 m and 3.03 m. These windows are to have Rosa Beta granite window sills on the outside. The thickness of the window sills is 3 cm and a depth of 25 cm.
Now my question to you: Is it possible to have single-piece window sills under these circumstances, or is it absolutely necessary or advisable to install two window sills per window at these widths?
Kind regards
