ᐅ Why does the MALM bed creak when getting up?
Created on: 5 Jan 2020 06:37
NONARAN
NONARAN
5 Jan 2020 06:37
Why does the Malm bed squeak when getting up? I own a Malm bed from IKEA, and I have been increasingly hearing an annoying squeaking noise when getting up. It seems to come from the connections between the side panels and the headboard. The sound mostly occurs when I push off the bed with my weight, that is, when rising from the lying position. I suspect that either screws have loosened or that wood is rubbing against wood at the joints, possibly due to moisture-related expansion. I have already tried tightening the screws, but the squeaking persists. Has anyone experienced this issue and can offer specific tips on how to permanently eliminate the squeaking? Which components are most commonly affected? Are there any proven home remedies or tools that effectively address this problem?
kaju67
5 Jan 2020 07:58
NONARAN schrieb:
Why does the MALM bed squeak when getting up? I own a MALM bed from IKEA, and I increasingly hear an annoying squeaking noise when getting up, which seems to come from the connections between the side panels and the headboard.
Hey, a squeaky bed is really annoying, especially in the morning! 🙂 Most of the time, it’s caused by the screws or slight friction from dry wooden joints. Try treating the connection points lightly with wax coating or silicone oil. That often helps. Use a thin layer of wax so nothing squeaks anymore, and you won’t have to keep tightening the screws. If the screws are worn out, retightening them or even using larger washers can work wonders. Good luck!
kla69
5 Jan 2020 09:15
NONARAN schrieb:
Does anyone have experience with this issue and can offer specific tips on how to permanently eliminate the squeaking?
The squeaking in MALM beds often results from several closely related causes. One reason is that the joints, especially wood-to-frame connections at the headboard and footboard, tend to warp slightly due to temperature and humidity changes. This leads to micro-movements between the panels and screw fittings, which produce the characteristic squeaking sound.
Another important factor is the assembly method: MALM beds have a single-piece particleboard frame and usually metal fittings. If the screw tension is reduced, small shifts occur that cause squeaking. Screws should therefore be retightened with a torque wrench, taking care not to over-tighten the particleboard.
A very effective measure is to apply furniture wax, candle wax, or graphite powder to the areas where the wood panels rub against each other to reduce friction and thus noise. It is also important to check whether the bed is placed on an uneven floor, as slight rocking movements can increase the noise.
How exactly is your bed assembled? Do you perhaps have an additional mattress topper or underlay that might amplify movements? Details like these help to pinpoint the cause more precisely.
NONARAN
6 Jan 2020 08:03
kla69 schrieb:
How exactly is your bed assembled? Do you perhaps have an additional mattress topper or pad that might be amplifying the movement?
Thank you for the detailed explanations. The bed is assembled in the standard way, with no additional pads except a regular mattress, and no slatted bed base. I have checked the floor: it is level, and the carpet underneath barely gives. I carefully tightened the screws, but there was no noise reduction. I am especially interested in whether the use of graphite powder actually provides long-term effect, since I have read that some lubricants can attract moisture and cause wood to swell. What other recommended but simple solutions are there to eliminate this noise?
tra_nina
7 Jan 2020 14:22
Nonaran schrieb:
I am particularly interested in whether the use of graphite powder actually shows long-term effects, as I have read that certain lubricants can attract moisture and cause wood to swell.
Graphite powder is indeed a proven solution in such cases because it remains dry and non-sticky, making it ideal for wood joints. Unlike oily or waxy lubricants, it does not attract moisture and effectively prevents wood swelling.
Alternatively, dry lubricants based on Teflon (PTFE) are also suitable and available in powder form or as a spray. These provide long-lasting friction protection without retaining moisture.
Before applying any lubricant, make sure all screws are tightened again to minimize movement of the joints.
I also recommend checking the bed for loose connections every 6 months – this helps prevent squeaking from recurring in the long term.
