ᐅ Why does my BILLY shelf make noise when loaded?
Created on: 7 Sep 2022 10:14
Nonmo69
I recently set up a Billy bookcase from IKEA, and I’ve noticed that it starts to rattle when it’s heavily loaded with books or other items. The noise especially occurs when I gently bump the shelf or when I place or remove something from it under load.
The bookcase is fully assembled, and all screws are tight, but it still makes this annoying noise. My question is: Why does my BILLY bookcase rattle under load?
Are there any known design weaknesses or anything I can check to prevent the rattling? I would appreciate any helpful insights, including suggestions on whether certain parts can be secured or dampened additionally.
Thanks in advance!
Ramon4
8 Sep 2022 10:46
Josefane schrieb:
if the problem reduces significantly for you when the back panel is retrofitted with nails or screws
In my experience, this is indeed a very effective measure that I often recommend. Often, the back panel on the IKEA BILLY bookcase does not fit tightly enough because the pre-drilled holes for nails or screws are slightly larger, leaving some play with the thin back panel.
By additionally securing it with small screws or nails (carefully, to avoid splitting), the back panel functions better as a stabilizing element. This limits the slight vibrations caused by loads or movements, thus significantly reducing rattling.
Furthermore, I would add that retrofitting felt pads under the feet is also advisable—not only to protect the floor but also to improve stability and provide some cushioning.
Glad to hear the previous tips have been helpful.
