ᐅ Why do some MALM drawers get stuck when closing?
Created on: 19 Apr 2021 20:07
fefar
fefar
19 Apr 2021 20:07
I have a problem with one of my Malm dressers where some drawers stick when closing or can only be fully closed with significant force. The issue doesn’t always occur in the same place; sometimes the drawer frame sticks slightly near the top, other times the problem is further back along the drawer slides.
I’m interested in what the typical causes for these problems with Malm drawers are and what specific points to check if I want to fix these issues permanently.
Does anyone have experience with adjusting or mechanical deformation of these systems? I have been using the drawers for several years and can rule out overloading, but the problem keeps occurring from time to time.
Thanks for your insights!
gadalu
19 Apr 2021 20:29
Jamming of MALM drawers can have several causes. First, it should be checked whether the drawers are properly seated in the runners and whether these are still correctly aligned. Especially with wooden furniture, slight deformations can occur due to moisture or temperature changes, which can hinder opening and closing.
Often, accumulated dust or dirt particles in the runners block the mechanism. A thorough cleaning and, if necessary, lubrication with a silicone-based product can help.
Another possible issue is incorrect installation or damage to the runner rails. I recommend addressing the problem based on these factors. Warped side panels or twisted fronts can also prevent proper closing.
Chendu
19 Apr 2021 21:41
Check the surface, clean the drawer slides, and readjust them if necessary. Screws are often loose, or the drawer may not be properly aligned.
Additionally, moisture can cause the wood to swell slightly, making it harder to close. Remove any excess load from the drawer – this often helps as well.
fefar
20 Apr 2021 09:53
gadalu schrieb:
due to moisture or temperature effects causing slight deformations
That sounds plausible to me, I have the chest of drawers in the bedroom where it sometimes gets quite warm and humid.
Chendu schrieb:
screws are loose or the drawer isn’t seated properly
I’ll check that right away.
I’m also interested to know if anyone has specific tips for adjustment—like which screws to tighten, how often, or in which direction—to make the drawer operate more smoothly, or if there are particular tricks that are especially relevant for MALM.
Thank you!
Julien
20 Apr 2021 14:18
Hello fefar,
I’m familiar with this issue and happy to help. The MALM drawers have side-mounted metal runners that can be adjusted. The most important step is to first fully remove the drawer in order to check the guide rails.
There are usually two small screws on each pair of rails that allow you to adjust the height and depth. If the drawer sticks, it’s very likely that it’s not running centered or that the rail is bent. Here are my specific steps:
1. Completely remove the drawer
2. Loosen the screws on the runners, gently move the rail into the correct position (horizontally and vertically)
3. Slightly retighten the screws and put the drawer back in
4. Test if the drawer now slides more smoothly
Be careful not to overtighten the screws, as this can warp the rails.
One more tip: Sometimes a slight adjustment of the front panel helps if it’s mounted too low and is rubbing against lower edges.
Good luck!
