ᐅ Why do some Billy shelves warp or bend after extended use?
Created on: 17 Dec 2017 09:37
Fada60
I have a rather specific question regarding the well-known Billy shelves from IKEA: Why do some Billy shelves warp after extended use, even though they were perfectly straight initially? I have noticed that especially with older models, but also with newer shelves after a few months or years, slight bending, shifting, or warping can occur. The panels often no longer lie flat, or the back panel no longer fits flush against the wall. Are there technical reasons or common usage mistakes that contribute to these changes? I’m also interested in structural or material-related causes, as I have recently read more about how engineered wood products can change when exposed to moisture or load. Does anyone have experience with this issue and possibly tips on how to prevent warping?
LAURE-TA
18 Dec 2017 08:49
I would like to add some tips on reinforcing the back panel and preventing warping:
1. Retrofitting with stronger back panels: There are thin but stiffer plywood or film-faced panels available at hardware stores that can be cut to size and installed as replacements for the original back panel. These provide much greater stability against warping.
2. Screws instead of nails: If the original back panel is fastened with small nails, replacing them with small screws can provide a firmer hold.
3. Diagonal bracing: Adding a diagonal board or metal brace on the back significantly improves rigidity.
4. Optimize load distribution: Distribute weight evenly and avoid placing very heavy items on individual shelves.
When mounting the shelving unit to the wall, always ensure it is attached to solid masonry and use appropriate anchors (wall plugs).
These measures can significantly extend the service life.
DUUS32
18 Dec 2017 10:12
I understand how frustrating it can be when a shelf warps – I experienced the same issue last winter! It really annoyed me because I felt like I had done everything correctly. However, it helped to reconsider the location and maintain consistent humidity, for example by using a dehumidifier nearby.
Perhaps it would be a good idea to check if the shelf is truly level or standing on an uneven floor, as that can also encourage warping. I just want to encourage you – small measures like these can make a big difference.
rekijan
18 Dec 2017 11:16
fasau schrieb:
Now I make sure that the shelf is not placed right next to the heater and that it’s not too damp.
That’s a good point! I think especially with furniture made from engineered wood, you should never underestimate how sensitive it is to its environment – almost like a little living thing that tries to avoid drying out or getting too moist 😄
I always leave a bit of space around my Billy shelves, so they’re not directly against the wall, allowing air to circulate. I also make sure not to overload them with heavy items – even that makes a big difference!
A little bit of gentle care, and the shelves will repay you with durability.
libar49
19 Dec 2017 16:41
Fada60 schrieb:
Are there any alternative ways to reinforce the back panel without ruining the Billy design, to your knowledge?
If the surface appearance of the back panel is less important, at least on the inside, you can definitely use sturdy diagonal battens. This is hardly noticeable but significantly increases stability.
Of course, you also need to critically consider the placement: a room that is never properly heated, has high humidity levels, or experiences direct sunlight through the windows with temperature fluctuations is very harmful to furniture made from particleboard.
I think Billy shelves are a real bargain, but you shouldn’t expect miracles in terms of durability.
