ᐅ Why do some BILLY shelves no longer fit into their alcoves?
Created on: 18 Jun 2022 10:37
Camilla_frC
Camilla_fr18 Jun 2022 10:37Hello everyone,
Over the past few weeks, I have repeatedly tried to install a new BILLY bookshelf from IKEA into an existing alcove in my home. I noticed that some of the new shelves, despite having the same model name and nominal dimensions, no longer fit into the alcove, even though similar models used to fit without any problems. I’m curious about why this is—is it due to changes in the dimensions of the BILLY shelves, or could it be related to the alcove itself?
Maybe it’s also due to manufacturing tolerances or another reason I’m not aware of. I’m especially interested if anyone knows why some BILLY shelves suddenly don’t fit into standardized alcoves anymore, even though this used to be normal. And if you have any advice on how to best handle this issue, I’d appreciate your input!
Thanks in advance for your insights.
The dimensions of the BILLY shelves have been slightly altered over the past few years. Often, the listed basic measurements remain the same, but the frame construction or the back panel may be thicker.
Also, your niche might have shrunk slightly due to moisture or construction work. Check the measurements carefully with a laser measure.
I can offer a more detailed explanation here:
IKEA has adjusted the BILLY bookcase several times over the years. Although the external dimensions have often remained officially the same, there have been subtle changes in material thickness, back panels, and fittings. For example, the back panels were reinforced from the original 3 mm to up to 4 or 5 mm, which slightly reduces the depth when you slide the bookcase into a fixed niche.
Another point concerns the natural materials: particleboard shelves can swell slightly due to moisture, so if the niche is not completely dry, it will become tighter. Additionally, some niches have become smaller due to plastering or changes to the walls – even a few millimeters can make a big difference here.
My advice: take precise measurements of both the niche and the bookcase (preferably at several points). If the bookcase is only slightly larger than the niche, sanding or removing the back panel (which is almost always made of thinner, flexible material) often helps.
Assembly can also affect the fit. If the drill holes are not perfectly aligned or the back panel is uneven, the bookcase may no longer fit properly.
In conclusion: the problem is almost never due to a single factor but results from the combination of slightly different product dimensions, changes in the niche caused by the living environment, and assembly-related factors.
tolokau schrieb:
IKEA has modified the BILLY shelf several times over the years.These kinds of changes always make me suspicious. Clearly, companies that produce cheaply adjust details to save costs or respond to new suppliers.
You shouldn’t be surprised if the "standard size" suddenly becomes inaccurate and no longer fits. Maybe IKEA also wants to encourage buying new shelves instead of old models – but not being able to use existing spaces anymore is frustrating for me.
nonpra schrieb:
Your niche might have shrunk as well.I consider that an excuse, because even if walls vary slightly, it doesn’t cause such large differences. The responsibility lies with the manufacturer and their changing standards. IKEA is big enough to guarantee consistent measurements if they wanted to.
Take this as a small warning: If you rely on precise measurements, sometimes you lose with IKEA.
