ᐅ Why do some parts of the back panel pop out in certain Billy bookcases?
Created on: 23 Oct 2015 14:27
Mauhau45Hello everyone, I have a rather technical question and hope to find some expertise here in the forum: Why do parts of the back panel on some Billy bookcases come loose? I mean that the thin back panel, usually made of particleboard or hardboard, detaches from its fixed mounting at certain points, sometimes sticks out, or even falls out completely. I have noticed that this happens quite quickly after assembly with some units, while others remain stable for a long time. I am mainly interested in the causes: Is it due to incorrect installation, poor material quality, excessive load, or possibly environmental factors like temperature or humidity? Additionally, I would like to know if there are proven solutions or tips to prevent the back panel from coming loose permanently. Thank you in advance for your answers!
Mauhau45 schrieb:
Why do parts of the back panel sometimes pop out of certain Billy shelves?This usually happens because the back panel is not properly secured, for example, if the nails or brads are not driven in deep enough. Excess humidity can also cause the material to swell, pushing the panel out. Simply reinsert the nails and store the unit in a dry place.
Tobias schrieb:
Too much humidity can also cause the material to swellExactly, that is often the culprit. The back panels of Billy shelves are relatively thin and don’t handle moisture very well. If the shelf is placed near a window or in a bathroom, where it can get steamy from time to time, the pressure from the swollen back panel can sometimes cause it to pop out. Applying a small strip of sealing tape along the edge can sometimes work wonders 😉.
I would like to add that material stress caused by temperature fluctuations also plays a role. The back panel is relatively thin and flexible, while the carcass remains rigid. Especially in areas where the back panel is fixed only with small nails, gaps can form when the wood expands or contracts slightly. A more secure attachment with more or stronger nails, or small screws that cause less damage to the material, can help. It is also advisable to install the panel precisely, without large gaps.
Since it often depends on the material, I would recommend carefully trimming the back panel during assembly to ensure an exact fit. If it is too large, it will press outward uncontrollably. Also: never insert the back panel only after assembly; instead, secure it while assembling so it fits better.
praWarre6924 Oct 2015 09:42Mauhau45 schrieb:
Are there any proven solutions or tips to permanently prevent the back panel from popping out?Yes, there are! Besides the previously mentioned sealing tape (or a thin felt strip) between the back panel and the carcass, which cushions against swelling, you can also use a few additional small nails. Important: The back panel should not be too tightly tensioned, otherwise stress will build up that causes it to pop out. If you’re handy, applying a thin coat of paint or varnish on the back panel can also help, as it reduces moisture absorption.
