ᐅ Why do some parts of the back panel pop out in certain Billy bookcases?
Created on: 23 Oct 2015 14:27
Mauhau45
Hello everyone, I have a rather technical question and hope to find some expertise here in the forum: Why do parts of the back panel on some Billy bookcases come loose? I mean that the thin back panel, usually made of particleboard or hardboard, detaches from its fixed mounting at certain points, sometimes sticks out, or even falls out completely. I have noticed that this happens quite quickly after assembly with some units, while others remain stable for a long time. I am mainly interested in the causes: Is it due to incorrect installation, poor material quality, excessive load, or possibly environmental factors like temperature or humidity? Additionally, I would like to know if there are proven solutions or tips to prevent the back panel from coming loose permanently. Thank you in advance for your answers!
labau
24 Oct 2015 10:05
Another point that is often overlooked: During transport, the back panel can start to come loose if the shelving unit is shaken or turned upside down. So after assembly, calmly check whether the back panel is still properly in place and the staples are secure.
Mauhau45
24 Oct 2015 16:33
barge schrieb:
A small strip of sealing tape along the edge can sometimes work wonders
Thanks for the tip, the idea of using sealing tape sounds reasonable, especially when moisture is an issue.
sonplo schrieb:
Temperature fluctuations can cause gaps to form
Interesting, I had only thought about moisture so far, but I can see that happening with my shelves too, as they were placed close to radiators.
Next time, I will definitely install the back panel during assembly and try using more nails; maybe the original clips aren’t really enough. Thanks for all the helpful advice and the notes on installation and environmental factors!
