ᐅ Which screws are suitable for heavy loads?
Created on: 17 Aug 2023 09:23
Myron
Myron
17 Aug 2023 09:23
I am currently planning a project where I need to attach heavy loads to a wood and metal structure. The central question for me is: which screws are best suited to reliably and permanently ensure a high load-bearing capacity?
Important factors for me are maximum load capacity, corrosion resistance (since parts will be outdoors), material compatibility with wood and metal, as well as ease of installation.
Can anyone with experience or expertise provide advice on which types of screws are especially suitable for heavy loads? For example, wood screws versus machine screws, thread types, material grades (stainless steel, galvanized, etc.), diameter, or screw length?
I am also interested in which standards or safety factors are typically considered in such cases.
I look forward to well-informed answers and also welcome tips on common mistakes to avoid when dealing with load-bearing connections.
Dilen
17 Aug 2023 11:37
Hello Myron,
your question is very well framed, and the fact that you already specify the different application parameters shows that you have seriously engaged with the topic.
In principle, there are several key factors to consider when selecting screws for heavy loads:
1. Screw material: Stainless steel (e.g., A2 or A4) is especially suitable for outdoor use due to its corrosion resistance. Zinc-coated screws are cheaper but less durable under weather exposure.
2. Thread type and shape: For wood, full thread screws with coarse threads are commonly used to optimize holding power in the wood. For metal connections, machine screws with fine, metric threads are standard.
3. Screw diameter and length: Load capacity increases with diameter, so for heavy loads, you should choose at least M8 or larger. The length must provide sufficient embedment in the supporting material – for wood, at least twice the diameter as embedment depth, and for metal depending on the use of threaded inserts.
4. Screw strength class: For high loads, screws with strength classes 8.8, 10.9, or even 12.9 are recommended. These ensure high tensile and shear forces.
5. Additional securing: Washers, lock nuts, or clamps prevent loosening due to vibration.
It is also useful to note that standards such as DIN EN 14399 for high-strength bolts in steel connections or DIN 571 for wood screws serve as a basis for design and dimensioning.
A common mistake is choosing screws that are too short or too thin without sufficiently considering the loads. Also, incorrect material combinations leading to corrosion from contact between different metals should be avoided.
Could you specify more precisely the loads (weights) and the type of construction you are planning? That could help tailor the recommendations more accurately.
neoren
17 Aug 2023 12:02
for heavy loads, it is best to use high-strength bolts with a property class of 10.9 or 12.9. Use stainless steel A4 if exposure to outdoor conditions is important.
For wood: whenever possible, use wood construction screws with coarse threads, with a diameter of at least M8.
The screws should be long enough to embed at least three times the screw diameter into the wood.
andre3
18 Aug 2023 10:44
Dilen schrieb:
A common mistake is choosing screws that are too short or too thin, without adequately considering the loads involved.
I want to emphasize this point. Additionally, it is important to note that for screws used in structural connections, the design must comply with the relevant technical standards, such as Eurocode or DIN-EN standards.
For loads applied to wood, it is recommended to use screws with sufficient thread length and the proper embedment depth to avoid splitting the wood and to transfer the loads effectively.
The screw material must also suit the application: In outdoor environments, choosing A4 stainless steel provides better corrosion resistance. Zinc-coated screws are less resistant but more affordable.
For metal connections, the combination of screw diameter, thread pitch, and strength class is crucial to safely withstand shear forces in particular.
Finally, proper installation is always essential: Screws should be tightened with the correct torque to ensure a permanently secure connection.
Layla
19 Aug 2023 08:07
Hello Myron,
I can fully understand how complex choosing the right screw is, especially when safety is involved. Your question is very thorough, which shows that a reliable connection is important to you.
From my own experience, I would add that besides technical details, it is also helpful to always consider the surrounding conditions – for example, if wood becomes damp or metal parts are exposed to temperature changes. These situations often cause issues that can be minimized by careful screw selection and, if necessary, additional coatings.
Additionally, planning and later inspection go hand in hand. I would recommend paying close attention to following the guidelines precisely during installation and, if possible, checking the connection afterward, especially when loads are very high – this ensures safety and good results.
Best regards and good luck with your project! 🙂
