ᐅ Which Ikea Metod cabinet sizes fit into a standard kitchen space?
Created on: 30 Jul 2023 14:23
bijusu
bijusu
30 Jul 2023 14:23
I am currently redesigning my kitchen using the Ikea Metod system and am wondering which cabinet sizes from the Metod range are best suited for a “standard kitchen space.” By that, I mean rooms with typical dimensions of about 2.5 to 3 meters (8 to 10 feet) wall length and a standard ceiling height of around 2.40 to 2.50 meters (7 ft 10 in to 8 ft 2 in). I am especially interested in which widths, heights, and depths of the Metod cabinets work best together without needing complicated modifications.
Are there standard combinations that work particularly well for typical kitchen rooms? Also, which modules can be placed side by side efficiently to make the most of the available space? I look forward to your insights and experiences!
Fitigu
30 Jul 2023 16:41
Regarding the question of which Ikea Metod cabinet sizes fit into a standard kitchen space, the following can be said:
- Width: The standard widths for Metod cabinets are 30, 40, 60, and 80 cm (12, 16, 24, and 32 inches). For rooms with wall lengths between 2.5 and 3 meters (8 to 10 feet), combinations of 60-cm (24-inch) and 40-cm (16-inch) cabinets are the most flexible and common.
- Height: Cabinet heights generally come in 80 cm (31½ inches), 80+40 cm (31½ + 16 inches), and 80+80 cm (31½ + 31½ inches). Classic base cabinets have a height of 80 cm (31½ inches) without legs; when planning for kickboards and countertops, total heights between 90 and 92 cm (35½ and 36¼ inches) are standard.
- Depth: The standard depth for base cabinets is 60 cm (24 inches), which fits well in typical kitchens. For wall cabinets, 40 cm (16 inches) depth is common to ensure sufficient head clearance.
It is generally recommended to install base cabinets at 60 cm (24 inches) depth and wall cabinets at 40 cm (16 inches) depth, as this meets ergonomic requirements and suits standard kitchen layouts. For narrower spaces or recesses, shallower modules are also available but used less frequently.
In summary, it makes sense to plan with modules that are 40, 60, or 80 cm (16, 24, or 32 inches) wide and to consider the standard heights of 80 cm (31½ inches) plus kickboard height for base cabinets and 40 cm (16 inches) depth for wall cabinets. This way, Metod cabinets usually fit standard kitchens well without the need for modifications.
Nathanaelk
31 Jul 2023 09:18
Additionally, I would like to address some technical and practical aspects that are crucial when choosing the right Ikea Metod cabinet sizes for standard kitchen spaces.
First, I recommend precisely measuring the room dimensions before selecting the exact cabinet widths and heights, including any obstructive elements such as radiators, electrical outlets, or window sills. This will determine which cabinet types can be used without major modifications.
For reference:
- Widths: Metod cabinets come in 20-cm (8 inch) increments, with common sizes being 20, 40, 60, and 80 cm (in some cases also 100 cm (39 inch) in special modules).
- Heights: Base cabinets typically have a height of 80 cm (31.5 inch) plus a 10 to 12 cm (4 to 5 inch) plinth, resulting in a countertop height of about 90 to 92 cm (35 to 36 inch)—ideal for ergonomic working height.
- Depth: Standard base cabinets with a depth of 60 cm (24 inch) provide a comfortable workspace, while wall cabinets usually have a depth of 37 or 40 cm (15 or 16 inch), offering sufficient storage without appearing bulky or top-heavy.
In standard kitchens with wall lengths around 2.5 to 3 meters (8 to 10 feet), for example, two 60 cm (24 inch) base cabinets and one 40 cm (16 inch) cabinet can be combined nicely, or alternatively three 60 cm (24 inch) cabinets if space allows.
It is also important to consider the distance between the wall cabinets and the countertop, which should be about 50 cm (20 inch). With this spacing, standard wall cabinet heights of 70 to 80 cm (28 to 31.5 inch) and a depth of 40 cm (16 inch) are suitable.
I am also wondering about the ceiling height in your room, as Ikea now offers taller wall cabinets at 80 cm (31.5 inch) height, and sometimes an additional cabinet row or taller modules can be useful.
Which appliances do you plan to integrate? Oven, sink, refrigerator? Some Metod modules are specifically designed for these and significantly influence the overall width and layout.
I would advise using the Ikea kitchen planner based on your room dimensions and experimenting with different cabinet widths to find the optimal balance of functionality and design.
I’m happy to provide more detailed assistance with specific measurements and requirements.
BOMILAN
1 Aug 2023 11:07
For standard kitchen spaces, the following usually fit well:
- Base cabinets with a width of 60 cm (24 inches) and a depth of 60 cm (24 inches)
- Wall cabinets with a height of 80 cm (31.5 inches) and a depth of 40 cm (16 inches)
- Widths of 40 cm (16 inches) or 60 cm (24 inches) for flexible combinations
These are the most commonly used dimensions that work without adjustments.
