ᐅ Which Billy shelves have the highest load capacity?
Created on: 24 Mar 2021 10:03
alican_bar
alican_bar
24 Mar 2021 10:03
I am currently planning to buy several Billy bookcases from IKEA and would like to get more detailed information: Which Billy bookcases have the highest load capacity? I am especially interested in whether there are differences in maximum load depending on the various widths, depths, or additional versions such as those with glass doors or adjustable shelves. It would also be helpful to know if certain installation measures (e.g., adding extra back panels or anchors) can significantly increase the load-bearing capacity. I mainly want to store many, and sometimes quite heavy, books in the shelves. I would appreciate any experiences or specific figures. Thanks in advance!
nojaus
24 Mar 2021 11:17
alican_bar schrieb:
Which Billy shelves actually have the highest load capacity? I’m especially interested in whether there are differences in maximum load depending on the various widths, depths, or additional options like glass doors or extra shelves.
I understand the concern when you have a lot of books and the shelves need to hold up. I was unsure for a long time myself because IKEA shelves are often made from relatively thin wood materials. In my experience, the standard Billy shelf with 40 cm (16 inches) depth and 80 cm (31.5 inches) width usually holds up to 30 kg (66 lbs) per shelf when mounted to the wall. However, if you load more weight and consider the thickness of the shelves, some boards may bend more quickly, especially with prolonged use. Have you considered adding extra metal brackets or reinforcements? Otherwise, it can feel a bit insecure, particularly with heavy collections.
FLOMARCOS
24 Mar 2021 11:24
The standard Billy version with a width of 80 cm (31.5 inches) can support up to approximately 30 kg (66 lbs) per shelf when properly mounted to the wall. Wider models (100 cm / 39.4 inches) do not have a higher load capacity per shelf. For heavy books, it is better to use several smaller shelves.
Metal brackets significantly increase stability.
nonere
24 Mar 2021 13:42
Regarding the load capacity of Billy bookcases: According to IKEA, the maximum load for a single shelf is around 30 kg (66 lbs) when the unit is properly secured to the wall. This generally applies to the standard shelves with a depth of 40 cm (16 inches).
Important: Bookcases with glass doors often have a lower load capacity because the fixed inserts reduce flexibility.
Basically, the load capacity is the same across the different widths (40, 60, 80, 100 cm) since the limit depends on shelf sagging and the material.
A significant increase in load capacity can be achieved by adding additional reinforcement strips or metal brackets – those storing heavy books should also secure the bookcases against tipping.
My recommendation: Rather than choosing a very wide bookcase, it’s better to place several standard Billy units side by side and secure them properly.
giabau
24 Mar 2021 16:02
A brief guide and explanation regarding the load capacity of Billy shelves:
1. Basic information: IKEA specifies a maximum load capacity of 30 kg (66 lbs) per shelf, assuming proper wall mounting.
2. Influence of dimensions:
- Wider shelves (100 cm (39 inches)) put more stress on the shelf panel, which is why these shelves often have a lower load capacity than narrower ones (~80 or 40 cm (31 or 16 inches)).
- Depth (30 vs. 40 cm (12 vs. 16 inches)) has less impact on load capacity but is more relevant for larger books.
3. Material thickness and reinforcement:
- Standard shelves are about 1.5 cm (0.6 inches) thick; for heavy loads (over 20 kg (44 lbs)), adding a wooden strip underneath the shelf as reinforcement is recommended.
- Metal brackets in the corners or additional metal supports improve stability.
4. Doors and fixed shelves:
- Glass doors and fixed shelves have little effect on increasing load capacity, but due to their fixed installation, they can help stabilize the shelf unit.
5. Wall mounting:
- Absolutely essential to reduce tipping risk and shelf sagging.
Summary: For maximum load capacity, it is advisable to use shelves no wider than 80 cm (31 inches), reinforce the shelves if necessary, and always mount the unit to the wall.
Fitigu
24 Mar 2021 18:15
It is true that the maximum load of 30 kg (66 lbs) per shelf is only achieved with wall mounting. Shorter shelves (e.g., 40 cm (16 inches) wide) are more stable because less bending occurs. Wider shelves, such as 100 cm (39 inches), tend to bend more easily, with a recommended load of only 20–25 kg (44–55 lbs) per shelf.
If you plan to store heavy items, it is advisable to install a cross brace or glue wooden strips under the shelves to significantly reduce bending.
