Hello everyone, I’m reaching out today with a specific question about IKEA BILLY bookcases. I am looking for a version or model of the BILLY that is especially suitable for holding a large number of heavy books. Since I own many hardcover professional books and thick tomes, I want to avoid the shelves bending or becoming unstable. Perhaps some of you know about special models, additional reinforcements, or tips on how to improve the load capacity of the BILLY bookcases. I am also interested in whether there are significant differences between the typical variants (for example, height, width, or material reinforcement) and whether accessories or modifications might be useful. I look forward to your well-informed experiences and recommendations!
Hello ljubo53, your question addresses a common concern among many users of BILLY shelves. Basically, BILLY shelves are designed to hold standard books without any problems, but when it comes to very heavy, thick books, there are a few factors to consider in order to prevent sagging.
First, regarding materials and dimensions: The standard BILLY shelves with a width of 80 cm (31.5 inches) and a depth of about 28 cm (11 inches) are more stable than the narrower versions. You can achieve higher load capacity by choosing shelves with middle shelf reinforcement or by installing additional shelves made from stronger material yourself.
IKEA also offers metal fittings for the back panel that can significantly increase stability. The back panel is a crucial element for heavy books because it prevents the shelf from tipping backward or twisting.
If you have many very heavy books weighing more than 20 kg (44 lbs) per shelf, I recommend reinforcing the shelves with strips or metal braces when installing them. Some users report that adding an additional support bar directly under the shelf greatly improves load-bearing capacity.
I hope this gives you a first overview. If you like, I can also provide a simple construction suggestion on how to reinforce existing BILLY shelves afterward.
ljubo53 schrieb:Your concern is valid – better stability can only be achieved through such reinforcements or by distributing the books across several shelves instead of putting everything on one.
Da ich viele gebundene Fachbücher und dicke Wälzer besitze, möchte ich vermeiden, dass die Regale sich durchbiegen oder instabil werden.
In short: Use the BILLY shelving system with metal shelf supports. These are more load-bearing.
For extra heavy books, you should use wooden or metal shelves with additional brackets.
You can replace thin particleboard back panels with MDF boards, which improves stability.
And it’s better to distribute the weight across several shelves.
Hello ljubo53, your question about BILLY shelves and their suitability for heavy books is very interesting and deserves a detailed answer. First of all, it is important to understand that BILLY shelves are basically designed for normal use and storing standard books. The typical components consist of particleboard with a thin melamine veneer – this works well under moderate loads but reaches its limits with heavy fillings.
Regarding load limits: individual shelves usually support about 15 kilograms (33 pounds) without visible sagging. If this value is exceeded, typical sagging occurs, which over time can also affect the stability of the shelf. BILLY shelves with a width of 80 cm (31.5 inches) offer somewhat better load-bearing capacity than the narrower 40 cm (15.7 inches) versions, since the shelves are less heavily loaded, but they are still limited.
One tip for more stability is to add additional support strips under the shelves or to convert completely to metal shelf supports. These can help distribute the load more evenly. It has also proven effective to replace the thin back panel – which in BILLY shelves only roughly stabilizes – with a 6-10 mm (0.24-0.39 inch) MDF board, firmly screwed in place. This significantly increases the rigidity of the cabinet.
Furthermore, you should consider that securing the shelves to the wall is mandatory to prevent tipping, especially when fully loaded.
This is a very good point because these reinforcements distribute the load much better onto the side panels, preventing the shelf from sagging.
In conclusion, in my view the best option, if you already have the BILLY shelves, is to upgrade them with better supports and stronger back panels. Alternatively, wider shelves around 80 cm (31.5 inches) are an option, or even combining them with other heavy-duty shelving units if you have lots of very heavy books. How much space do you have available, and roughly how heavy are your book collections per shelf?
gregto schrieb:
If you have many very heavy books that exceed 20 kg (44 pounds) per shelf, I recommend reinforcing the shelves with strips or metal braces when placing them.
