ᐅ Which Billy models are the most stable for storing books?
Created on: 7 Jan 2020 14:02
KYLERLEN
KYLERLEN
7 Jan 2020 14:02
I am facing the challenge of finding the most stable Billy model for the permanent and secure storage of a rather large book collection. The shelves should not bend or become unstable, even when filled with many heavy books. My specific question is: Which Billy models from Ikea are considered especially stable for storing books?
I am particularly interested in how different variations (e.g., fixed back panels vs. open back panels, different heights and widths, material thicknesses) perform in terms of load capacity and stability. If anyone has experience with additional solutions like shelf anchoring or reinforcements, that would also be very helpful.
I would appreciate a well-founded assessment, as I am currently planning and would like to consider future load and durability.
Chendu
7 Jan 2020 14:27
The classic Ikea Billy bookcases with fixed back panels are sturdier than the open versions.
If you are storing heavy books, I recommend the wider Billy model (80cm (31.5 inches) wide) in the tall version.
Additional anchoring to the wall is mandatory to prevent tipping.
posin50
7 Jan 2020 15:05
Hey, great question, very important, especially if you have a lot of books! 🙂
I have the large Billy with an 80 cm (31.5 inches) width and all solid back panels, and I’m really impressed with how sturdy it is. It holds a lot of weight without any issues!
Pro tip: If you reinforce the shelves with support clips and maybe a thin board underneath, you can distribute the weight even better! Really useful! 🙂
rebufar
7 Jan 2020 16:53
Chendu schrieb:
The classic Ikea Billy shelves with fixed back panels are more stable than the open versions.
I agree with that, but I wonder if that’s really the deciding factor.
In my opinion, any Billy unit tends to start sagging pretty quickly once the shelves are fully loaded. It just isn’t designed for very heavy loads. A bit of stacking and the shelves bending is almost inevitable, no matter how wide it is.
Wouldn’t it make more sense to consider alternatives—perhaps other systems or at least metal shelving?
Billy is nice and affordable, but in my experience, it’s not as sturdy as many claim.
Karsten45
7 Jan 2020 18:14
Oh, rebufar is not entirely wrong, but hey, Billy does its job well when handled properly! ;-)
Of course, it’s not a heavy-duty shelving unit, but with a width of 80cm (31.5 inches), a solid back panel, and being anchored to the wall, it provides much more stability than you might expect.
Also, a bit of care and correct handling make a big difference. Don’t stack books too high, and store heavier volumes at the bottom. This way, it really lasts a long time.
Oh, and small tricks like adding extra support blocks at the bottom can work wonders! 🙂
theo63
8 Jan 2020 08:46
It is interesting to see the diverse experiences shared here. I would like to add that there are several technical factors to consider when assessing the load capacity of Billy shelves.
The stability is mainly influenced by the depth (standard 28cm (11 inches)) and the width. Larger shelves (80cm (31 inches) wide) tend to sag more due to the longer shelf boards. Additionally, the shelf supports play a significant role: stronger hanging brackets can hold more weight, but the shelf itself limits the total load.
Ideally, I recommend a combination of the wider version with additional center supports or a glued strip underneath the shelves.
The fixed back panel is undeniably advantageous for stability, as it protects the shelf against lateral shear forces.
