ᐅ What to do about squeaky Malm beds?
Created on: 9 Sep 2021 08:37
Ronanjon
Ronanjon
9 Sep 2021 08:37
Hello everyone, I have been having an issue with my Ikea Malm bed for some time: it squeaks quite loudly when moving or turning. The squeaking mainly occurs at the joints of the wooden parts, especially around the central support beam and the bed sides. I have already tried tightening the screws, but that only helped temporarily. I am interested in what specific causes might be behind the squeaking in a Malm bed and what long-term solutions are best without having to completely disassemble or damage the bed. Are there any home remedies or suitable lubricants that could help? I want to avoid damaging the wood with oil or grease. Thanks for your experiences and tips!
JULIANNALO
9 Sep 2021 09:45
Squeaking usually occurs due to friction between wooden parts or between metal and wood. Regularly tightening screws is the most important measure. If that is not sufficient, applying a thin layer of wax (such as candle wax) to the friction points can help. Oil is often too liquid and tends to stain the wood. If possible, stick felt or rubber strips between the contact surfaces to reduce friction.
Parbo
10 Sep 2021 14:23
Hello @Ronanjon, I understand your issue well because I had a similar problem with a Malm bed. The squeaking usually occurs where wood rubs against wood or metal rubs against wood without any padding. In your case, when you mention "especially at the center support and the bed sides," it sounds like pressure points where the connection isn’t completely stable. First, systematically loosen all screws, then carefully check the joints for cracks or improperly fitted wooden parts. Next, lightly sand these areas with fine sandpaper (very gently!) to remove any excess wood causing friction. After that, you can apply special dry lubricants: graphite powder is ideal here because it doesn’t stick or damage the wood. You can apply it thinly with a brush. Wax also works but is less durable. Important: Do not use regular oil or WD-40 – they attract dirt like a sponge and damage the wood over time. Finally, secure all screws with threadlocker (e.g., medium-strength Loctite) to keep them tight. Can you specify exactly which screws you have already tightened? Often, for example, the center support is only loosely hooked in, and the solution is a small reinforcement with a suitable wooden block or a rubber buffer to prevent any wobbling.
nanidra
11 Sep 2021 18:03
It’s interesting how the immediate recommendation is often some kind of lubricant.
JULIANNALO schrieb:
"Regularly tightening screws is the most important thing."
Of course, but isn’t the problem more symptomatic of a design flaw? The Malm series isn’t known for high-end furniture, so I would have expected such squeaking to be considered normal. Sometimes I wonder if we simply don’t prioritize stable quality enough and too quickly resort to repair mode. How about a practical tip: permanently isolate the friction surfaces with foam rubber or self-adhesive felt to prevent squeaking easily, without constantly turning screws?
Parbo schrieb:
"Graphite powder is ideal here because it doesn’t stick or damage the wood."
No doubt, graphite is great, but why complicate things when inexpensive insulation strips serve the same purpose? Just my two cents—I suppose opinions will vary here.
