ᐅ What should be considered when retrofitting BILLY lighting systems?
Created on: 28 Jun 2020 14:07
rokebu
rokebu
28 Jun 2020 14:07
I am planning to retrofit the lighting system of BILLY and would like to know what I should definitely consider. Specifically, I am interested in aspects such as the compatibility of the light bulbs, the power connection in the shelf, possible cable routing, and whether there are any special safety instructions for the installation. It would also be helpful if someone could explain any particular considerations when choosing the type of lighting, for example LED versus traditional bulbs. What preparations and tools are recommended to ensure a smooth and safe retrofit? Tips and experiences would be greatly appreciated, as I want to avoid any problems with installation or safety afterwards.
lalutau
28 Jun 2020 15:32
When retrofitting the BILLY lighting system, several important points must be considered. First, ensure that the chosen light bulbs are compatible with the intended power connections and sockets in the shelving unit. BILLY shelves typically use 12V LED systems or alternating current variants, so the power supply must be carefully checked. Second, cable routing should be arranged so that no edges or moving parts can damage the cables. For safety reasons, all connections must be secure, using appropriate plugs or clamps to avoid contact issues. Additionally, I recommend calculating the electrical load before installation to ensure the power supply beyond the shelving is not overloaded. Regarding the light bulbs, LEDs are preferable because they generate significantly less heat and are more energy-efficient. This simplifies installation and minimizes risks such as melting or fire hazards. Tools like screwdrivers, wire cutters, and a multimeter are essential to properly lay out and test the wiring. Please also verify whether local regulations concerning electrical installation apply, as in some countries a qualified professional may be required.
Ramon4
29 Jun 2020 09:18
A detailed addition regarding the retrofit of the BILLY lighting: It is important to test before starting the installation whether the existing wiring is compatible and if the power supply provides sufficient capacity for additional LEDs. Many overlook that insufficient power can cause flickering or premature failure. Additionally, I strongly recommend measuring the cable lengths and, if necessary, using appropriate extensions with the original connectors to ensure a tidy appearance and avoid trip hazards. Furthermore, the shelf should be completely emptied, and the assembly should be carried out in a well-lit area to perform all steps safely and precisely. Depending on the BILLY shelf model, there are differences in the mounting points for the lights – so checking the manual beforehand is advisable. I have had good experience with self-adhesive LED strips that can be easily attached behind the top shelf panel. They are discreet and provide pleasant illumination without glare.
Genevieve
29 Jun 2020 11:42
lalutau schrieb:
BILLY shelves usually use 12V LED systems or alternating current variants, so the mains connection should be carefully checked.
I would like to add to this and raise a critical question: Are there really only these two standard variants? I have seen retrofit kits where voltages and connection types vary significantly, especially with older or third-party accessories. It would be helpful to have a reliable source indicating which models support which technology to avoid risks with electrical connections.
Furthermore, we talk about "safety instructions" and "local regulations," but which exactly are these? Isn’t there a lack of a uniform standard or certified approval mark that should be checked before purchase? In my opinion, when it comes to retrofitting electrical installations, focus should be on certified components that are critically evaluated rather than blindly trusting originals or compatible parts.
Ramon4 schrieb:
Depending on the BILLY shelf model, there are differences in the fixing points for the lights – so prior research in the manual is advisable.
That sums it up well. The exact model and even the production period are important because mounting solutions can vary slightly. Therefore, I would verify the exact model number before any retrofit and not rely solely on a general instruction manual.
