ᐅ What common issues do people often experience with the IKEA BRIMNES in daily use?
Created on: 20 Feb 2022 08:23
isamlo
isamlo
20 Feb 2022 08:23
Some time ago, I purchased the IKEA Brimnes range, mainly dressers and wardrobes. However, I have noticed some issues in everyday use that I am curious to know if others are experiencing similar problems.
Specifically, I mean problems such as insufficient stability of the furniture under load, stiff drawer slides, creaking doors, or assembly difficulties that might be due to design flaws.
What experiences have you had with BRIMNES furniture in daily use? Are there any known weak points that should be considered before buying? I look forward to a constructive exchange to get a comprehensive understanding.
giabau
20 Feb 2022 14:47
Hello isamlo,
Your question about common issues with IKEA BRIMNES furniture is very relevant, as more affordable furniture lines often have minor and sometimes major problems in everyday use. I have personally used various BRIMNES pieces for several years and can share my experience.
Here is a structured overview of the most frequent issues:
- Stability: BRIMNES is made from particleboard with a melamine finish, which can weaken over time under weight, especially with taller cabinets. Without wall mounting, the furniture tends to wobble noticeably.
- Drawer slides: The standard metal slides are generally fine but may become sticky or start squeaking over time. Cleaning and lubricating them often helps.
- Doors: Problems mostly occur with the hinge hardware; incorrect adjustment can cause sticking or creaking.
- Assembly: Instructions are clear but not always unambiguous. Mistakes like incorrect dowel placement or using the wrong type of screws can affect stability.
Tip: Always check all parts for completeness before assembly and adjust hinges if necessary. If you want to prevent wobbling, don’t underestimate the importance of using the included wall mounts.
I hope this helps you.
letar
21 Feb 2022 09:35
giabau schrieb:
The common metal rails are acceptable but tend to become stuck over time or cause squeaking.
This matches my own observations. Regarding the drawer slides, it should be noted that BRIMNES typically uses simple roller guides rather than soft-close mechanisms. This leads to signs of wear or slight functional decline with regular use.
Furthermore, I would add that the material choice in BRIMNES poses a challenge: the particle boards are economical but limited in load capacity and ease of maintenance.
There are also reports that in high humidity, the coating may swell, which in turn affects the stability of the joints.
In summary, I consider BRIMNES an affordable option whose usability clearly reaches certain limits—especially with heavy use and in damp environments. Planning and assembly should therefore be carried out with particular care to minimize future problems.
taudi
22 Feb 2022 11:12
I would like to add some more detailed notes on assembly and maintenance, as many problems can be avoided by paying attention to certain points.
- Assembly: The BRIMNES system mostly uses connector fittings with dowels and Minifix fasteners. If there is any uncertainty about alignment, it is important to carefully check in advance whether all holes are drilled correctly, since incorrect positioning can quickly lead to warped fronts.
- Drawers: For sticky drawers, you can clean the rails and possibly apply some silicone spray to the runners, which often improves smoothness and reduces squeaking.
- Tip-over safety: Since BRIMNES furniture is usually quite narrow and tall, securing it to the wall is essential to prevent tipping hazards, especially in households with children.
- Load capacity: Although IKEA specifies a maximum load capacity, furniture parts should not be continuously overloaded to avoid chipboard breakage and deformation.
Conclusion: The problems that occur with BRIMNES in everyday use are often the result of assembly errors or improper use. Those who follow the assembly instructions can significantly reduce many weak points.
isamlo schrieb:
Welche Erfahrungen habt ihr mit den BRIMNES-Möbeln im täglichen Gebrauch gemacht? Gibt es bekannte Schwachstellen, die man vor dem Kauf unbedingt beachten sollte?
The answer is yes, weak points do exist but can often be managed well with care.
