ᐅ What is the feed-in tariff rate?
Created on: 29 May 2022 13:48
Heidi1965
Heidi1965
29 May 2022 13:48
In July 2021, we had a photovoltaic system with a capacity of 6.12 kWp installed. The battery storage with 5.1 kWh was finally delivered in March 2022. However, we have already fed more than 1,000 kWh into the public grid and continue to do so because we do not consume all the energy ourselves.
When I inquired with the local grid operator, I found out that the photovoltaic system had not been registered so far. I then asked the installer, who said this had been done. Ultimately, it seems it slipped through somewhere and is now being rectified.
Where can I check at what price the fed-in energy is being reimbursed? I once read something about 7 to 8 cents. That seems ridiculous, considering how much energy is in demand. Is there any other way to use the energy more effectively or sell it at a higher price? We are not planning to order an electric vehicle yet, as our old diesel cars still run well.
RotorMotor
29 May 2022 14:03
You need to register yourself as the operator in the market master data register!
You can find feed-in tariffs using any common search engine.
Heidi1965
29 May 2022 14:32
RotorMotor schrieb:
You have to register yourself as the operator in the market master data register!
You can find feed-in tariffs with any common search engine.
You register in the market master data register, but the network operator registration is done by the installer. Also, the commissioning data must match. I don’t even remember the exact date anymore.
In der Ruine29 May 2022 14:57
Heidi1965 schrieb:
I once read something about 7 - 8 cents. That’s really a joke, considering how much energy is in demand.
This consumer electricity price consists of three main components: 25% for electricity generation and supply, which goes to the energy provider; 52% for government-mandated taxes, fees, and surcharges; and 23% for the use of the power grid and billing services, which the grid operator receives.
Source: strom-report
You probably want the full 40 cents now, right? But then you also have to cover all additional costs.
i_b_n_a_n29 May 2022 18:20
Heidi1965 schrieb:
We had a photovoltaic system with a capacity of 6.12 kWp installed in July 2021. In March 2022, the battery storage with 5.1 kWh was finally delivered. However, so far we have fed around 1,000 kWh into the public grid and continue to do so because we don’t consume everything ourselves.
When I inquired with the local grid operator, I found out that the photovoltaic system had not been registered yet. I then asked the installer, who said it had been done. In the end, it seems this was overlooked somewhere and is now being corrected.
Where can I check the price at which the fed-in energy is being compensated? I read something about 7 - 8 cents per kWh. That’s actually a joke, considering how much energy is in demand. Is there another way to use the energy more efficiently or sell it at a better price? We don’t want to order an electric car yet, as our old diesel cars are still running well.
Don’t be discouraged; most current feed-in users are in the same situation. Photovoltaics combined with battery storage is already quite good. Simply use as much energy yourself as possible. With a heat pump running, self-consumption should be over 50%, otherwise less. That self-consumption represents the real profit. If you want to change your feed-in tariff, you either have to become politically active (be prepared for a lot of resistance) or build such a large photovoltaic system that you can sell your electricity on the open market. Currently, electricity prices on the exchange are often higher than the feed-in tariff.
