ᐅ What annual electricity consumption should I specify in the energy contract?
Created on: 9 Jun 2017 10:21
BigFlow
we will have two separate meters: one for the regular household electricity and one for our heating system. This consists of:
- Air-to-water heat pump with an outdoor unit for underfloor heating
- Exhaust air heat pump with a 200-liter (53-gallon) water tank for domestic hot water
- 150 sqm (1,615 sq ft) of usable space
When setting up the new electricity contracts, I would indicate 3000 kWh for household electricity (which has been roughly the consumption so far). For the heating electricity, I am unsure. I was thinking of 5000 kWh. Do you think that will be enough, or should I set it higher from the start? There are many varying reports on the consumption of such systems, so I prefer to estimate on the higher side to avoid unexpected additional charges.
Regarding these special heat pump tariffs with time-of-use restrictions, has anyone experienced the problem of suddenly running out of hot water while showering?
Thank you in advance.
Florian
Bieber0815
9 Jun 2017 22:25
No, this applies once you move into the completed house.
Alex85
10 Jun 2017 07:29
Exhaust air heat pumps are like roulette, unless it is a passive house. I would recommend including some buffer. Especially since domestic hot water is likely also supplied through it, there is a chance that the heat pump could turn into a pure electric heater.
BigFlow
10 Jun 2017 07:43
Well, only hot water is produced using the exhaust air heat pump. The underfloor heating is supplied by the air-to-water heat pump. Therefore, I will initially try to operate the exhaust air heat pump in eco mode (the electric heating element will not be used).
HilfeHilfe
10 Jun 2017 08:37
Better to have a few extra kW and deal with a later payment than to have too little. It also depends on the region you are in and how cold it gets.
Alex85
10 Jun 2017 14:35
BigFlow schrieb:
Well, the exhaust air pump is only used to heat domestic hot water. The underfloor heating is supplied by the air-to-water heat pump. Therefore, I will first try to run the exhaust air pump in eco mode (the electric heating element will not be used).
That's right, I overlooked that. But why do you have a separate exhaust air pump for domestic hot water? That doesn’t make any economic sense at all.
BigFlow
10 Jun 2017 18:04
Hmm, whether this makes economic sense, I might be able to tell you after a few winters 😉
The developer simply offered this combination in all the townhouse units, so we couldn’t choose anything else. Naively, I think that the outdoor unit only has to provide the 35°C (95°F) supply temperature for the underfloor heating in winter, and the exhaust air pump, which receives the heated air, can operate more efficiently.
