ᐅ What annual electricity consumption should I specify in the energy contract?
Created on: 9 Jun 2017 10:21
BigFlow
BigFlow
9 Jun 2017 10:21
we will have two separate meters: one for the regular household electricity and one for our heating system. This consists of:
- Air-to-water heat pump with an outdoor unit for underfloor heating
- Exhaust air heat pump with a 200-liter (53-gallon) water tank for domestic hot water
- 150 sqm (1,615 sq ft) of usable space
When setting up the new electricity contracts, I would indicate 3000 kWh for household electricity (which has been roughly the consumption so far). For the heating electricity, I am unsure. I was thinking of 5000 kWh. Do you think that will be enough, or should I set it higher from the start? There are many varying reports on the consumption of such systems, so I prefer to estimate on the higher side to avoid unexpected additional charges.
Regarding these special heat pump tariffs with time-of-use restrictions, has anyone experienced the problem of suddenly running out of hot water while showering?
Thank you in advance.
Florian
tomtom799 Jun 2017 12:05
That is definitely enough for starters 🙂
Lumpi_LE
9 Jun 2017 14:08
I would check the heating load calculation to see what it indicates. You can use it as a rough guideline; it will likely be lower. 5000 is a bit much...
BigFlow
9 Jun 2017 17:03
The heating load calculation shows 5 kW. If I multiply this by an assumed 2,000 operating hours and divide by the annual performance factor, that would result in approximately 5 * 2000 / 3(4) = 2,500 (3,400) kWh.
However, the calculation does not take into account the exhaust air heat pump for the domestic hot water at all.
Bieber0815
9 Jun 2017 21:41
In the first year, we consumed 4260 kWh (KfW70 standard, air-to-water heat pump, 154 m² (1657 sq ft), 4 people).
ares839 Jun 2017 21:51
@Bieber0815 Does that include the heating-up program?
