I’m planning to use an IKEA KALLAX shelf unit as a workbench since I currently don’t have space for a proper workbench. Before I get started, I’d like to hear about your experiences—especially regarding stability, load capacity, and possible modifications.
How have you reinforced or upgraded the shelf? Does the work surface hold up well under heavier tools or when it’s occasionally tapped or knocked on?
Are there any issues with the height (standard KALLAX units are quite low), or how have you adapted it to suit your needs?
I’m looking forward to your assessments, tips, and any warnings if this project might not be ideal. Thanks in advance!
About a year ago, I repurposed the KALLAX shelf as a workbench and can share some insights.
First of all: the stability is perfectly fine for lighter tasks, especially if you secure the shelf to the wall using small brackets.
I used a 20 mm (0.8 inch) thick multiplex board as the work surface, which I attached directly to the KALLAX with screws. The board barely flexes and provides enough resistance for typical workshop tasks. However, I would advise against placing very heavy machinery directly on it.
I placed the shelf on wooden trestles to achieve the right working height. This works quite well and is flexible.
While the shelf isn’t made to withstand heavy hammering, with some care it’s a practical solution for hobby use. 🙂
Jekinu schrieb:
How did you reinforce or upgrade the shelf? Does the worktop withstand heavy loads, for example when handling heavier tools or occasionally tapping on the shelf?
Jekinu schrieb:
Are there any issues with the height (the standard KALLAX is quite low), or how did you adjust it to suit your needs?
Hello Jekinu,
Since you specifically asked about load capacity and modifications to the KALLAX as a workbench, here is my detailed experience:
From a technical point of view, the KALLAX shelving unit is designed for light to medium loads – you should not place more than about 13 to 15 kg (29 to 33 lbs) per compartment on the board long-term to protect the material and connections.
For a workbench, this means:
1. Reinforcing the basic structure: I installed diagonal braces made of metal profiles inside the unit to reduce lateral wobbling, as the original back panels and upright shelves tend to “flex” quickly under load pressure.
2. Worktop: The choice of worktop is crucial. Multiplex plywood or hardwood boards around 18 mm (0.7 inches) thickness work well, providing stability and preventing sagging.
3. Height: The standard KALLAX is 147 cm (58 inches) wide and 147 cm (58 inches) high, which is rather low for a workbench. I built an adjustable-height base frame from steel pipes to enable ergonomic working.
4. Protection: To protect the edges, I added an aluminum edge strip to the board – this also helps withstand frequent hammering.
5. Fastening: The board was screwed directly to the carcass with wood screws to prevent any movement. For heavier tasks, I recommend additional floor connectors to increase stability.
I am still wondering: What kind of work do you plan to do on the workbench? Small repairs or precise machine work as well?
This will help better estimate how much reinforcement is necessary.
I’m jumping in briefly because I’ve tried a similar solution myself:
I can definitely confirm this tip – plywood is almost unbeatable for DIY projects because it is very durable and relatively lightweight.
However, I had the issue that the original height of the KALLAX was too low for my height. That’s why I placed the workbench on sturdy wooden legs, which I adjusted precisely to my ideal height (about 90 cm (35 inches)). The workbench is now very stable and nicely flexible.
From my experience, I recommend fixing the panel not only with screws but also with wood glue to prevent any wobbling. Screws alone can loosen over time under heavy load.
One more personal tip: depending on how you use it, a thin rubber mat or a PVC cover on the surface can help protect sensitive surfaces, especially if you’re handling smaller tools or materials a lot.
Looking forward to seeing if you follow through with the project and what results you get 🙂
Joe52 schrieb:
I used a 20 mm (¾ inch) thick plywood panel as the work surface
PEDRO40 schrieb:
Based on experience, I recommend securing the panel not only with screws but also with wood glue to prevent any wobbling.I find this point very important, especially when using a KALLAX as a workbench! Screws alone absorb tensile forces but can loosen over time due to vibration or occasional impact. Wood glue distributes the forces and creates a permanent bond that is significantly more stable.
It is important to ensure that the panels are clean and free of grease so that the glue properly adheres. Additionally, you can fill in around the screws with wood filler to keep the screw heads flush and maintain a smooth work surface.
Joe52 schrieb:
I placed the shelf on saw horses to achieve the right working height.That is a good solution, but you should be careful about stability—unsturdy saw horses or those without non-slip feet can be dangerous when hammering on them.
One more note: The back panel of the KALLAX is typically thin. When subjected to heavy loads, it can help to screw a plywood sheet onto the back to prevent bowing.
I would recommend doing smaller load tests at first before relying on the shelf as your main workbench, especially if planing, sanding, or drilling are part of your regular tasks.
