ᐅ Should you use lime-cement plaster or gypsum plaster for interior walls?
Created on: 17 Oct 2018 22:04
blaupuma
Hello, we are currently trying to decide whether to use lime-cement plaster or gypsum plaster in the living areas.
Gypsum plaster is cheaper and results in a smoother wall. However, we are leaning slightly towards lime-cement plaster because it is said to be more impact-resistant and to improve the indoor climate.
Everyone recommends something different :-(
Are there any people here who have lime-cement plaster in their living areas and can share their experiences?
Alex85
18 Oct 2018 06:36
Plaster is the usual choice, probably more for cost reasons. In my opinion, lime-cement plaster is of higher quality but has a different texture, which can be quite appealing. It is moisture-resistant, but that doesn’t make it the exclusive “wet room plaster.” It’s simply a positive feature—or a negative for gypsum plaster (as is its sensitivity to impact).
I won’t comment on any so-called indoor climate gurus.
BendFlad18 Oct 2018 12:13
We have chosen a lime-cement plaster. Although we haven’t started using it yet, my brother is very satisfied with it.
Mottenhausen
18 Oct 2018 14:46
Nowadays, almost every floor plan includes an open kitchen, which should actually settle the question of having a wet area in the living room. Due to various energy-saving regulations or mechanical ventilation requirements, recirculating range hoods are often installed. While the potatoes are simmering, the steam moves around the living room. Gypsum plaster can swell. Lime-cement plaster does not.
truce18 Oct 2018 15:11
Mottenhausen schrieb:
Gypsum plaster can swell. Lime cement does not.
Clay plaster does not either. Lime as well... but both are probably in a higher price category – and also more challenging to paint.
Mottenhausen
18 Oct 2018 15:13
"Difficult" is relative. You have to accept that lime-cement mortar will have a certain grain size and won’t be perfectly smooth like a baby’s bottom. Don’t even get me started... clay, ... you.
Bookstar
18 Oct 2018 22:14
Nowadays, almost every floor plan includes an open kitchen, so the question of moisture exposure in the living room should basically be settled. Due to various energy-saving regulations or requirements for mechanical ventilation systems, recirculating range hoods are often installed. While the potatoes are simmering, the steam spreads through the living room. Gypsum plaster can swell when exposed to moisture. Cement-lime plaster does not.
So gypsum plaster does not swell just from potato steam. There would have to be more moisture involved. A kitchen is not considered a wet room.
