ᐅ Timber Frame Construction – Include a Service Cavity or Not?
Created on: 22 Feb 2015 20:20
TiBiHaus
TiBiHaus
22 Feb 2015 20:20
we are about to embark on the adventure of building a house and are planning to construct a timber frame house to KfW 55 standard.
One company has recommended an installation cavity for the exterior walls (“Useful to never compromise the airtightness of the house”), while another strongly advises against it (“Not necessary at all – just takes up space!”).
We are still undecided on the ideal wall construction. What should be considered regarding the airtightness of the walls? How about any later installation work? What are your experiences?
TiBiHaus
wrobel22 Feb 2015 22:15
Hello
Definitely include it.
Or do you want to seal every outlet and switch box as well as all cable penetrations airtight?
Olli
peps007
22 Feb 2015 22:31
Would that really be the case? A provider who works without an installation floor said that an air draft issue would not occur...
TiBiHaus
23 Feb 2015 07:04
The contractor mentioned airtight installation boxes that make it straightforward to achieve airtightness. That sounds plausible to me at first. But how does it work when modifying the installation later on?
K1300S23 Feb 2015 10:10
Of course, exactly the same, except that the (slightly more expensive) airtight box only makes sense if it is installed properly – and pulling cables afterwards is always somewhat problematic. I would also recommend the installation level if there is enough space.
Good luck
K1300S
Cascada23 Feb 2015 14:45
If you want to install something later on (pulling cables), and there is no installation level present, just make sure not to damage the vapor barrier. The sockets are already inside the “airtight” space anyway. If you know the wall construction and work carefully, there is no problem. And if the vapor barrier does get damaged, simply repair it with the appropriate system tape.
How often does this actually happen in practice? It’s better to plan for more sockets than fewer during the design phase—because you can never have too many.
