ᐅ Wall Construction Comparison: Heinz von Heiden vs. Team Massivhaus
Created on: 30 Jan 2024 15:38
AnnabellaA
Annabella30 Jan 2024 15:38Hello, we have two fairly comparable offers from the above-mentioned companies, but they differ in wall construction as follows:
Heinz von Heiden:
- Porous hollow brick T12, thickness 24 cm (9.5 inches)
- Polystyrene insulation boards (fire-retardant), thickness 16 cm (6.3 inches), thermal conductivity class 035
Team Massivhaus:
- Aerated concrete blocks (H+H), thickness 17.5 cm (6.9 inches)
- Mineral wool insulation (KD), thickness 12 cm (4.7 inches), thermal conductivity class 035
- Branded facing bricks
The total wall thickness is about 45.0 cm (17.7 inches).
Which wall construction would be considered higher quality? We assume the one from Team Massivhaus due to the facing bricks.
Thanks for your thoughts on this.
Heinz von Heiden:
Team Massivhaus:
Annabella schrieb:
Which wall construction is of higher quality? We are leaning towards the cladding of Team Massivhaus? If that is your line of thinking, we wonder how competent you are.
Annabella schrieb:
We have two relatively comparable offers on the table
from the aforementioned companies, which differ in the wall construction as follows: You are able to assess this. So you inquired about the same house (who planned it, and what type of exterior walls?) from two companies. And now one of them says they will build it with a different wall construction?
Or is it perhaps more like this: You requested a “roughly this is what we want” type of house, and both providers responded with building proposals that you see as having no significant differences?
From my point of view, Berlin does not primarily require a masonry cladding for weather protection. Both companies compared here are probably well known in this forum, with Team Massiv being, in my opinion, the somewhat more reputable business partner than Heinz von Heiden—though both would be preferred over a more locally limited provider than Team Massiv if in doubt. For example, have you also considered KB Brandis or Mein Haus (in Nauen, with whom, to my knowledge, @motorradsilke and @Nida35a have built)?
Annabella schrieb:
- Porous high-perforated brick T12, thickness 24 cm (9.4 inches)
- Polystyrene insulation boards (flame-retardant), thickness 16 cm (6.3 inches), thermal conductivity class 035 The weatherproof exterior finish is completely missing here, whether plaster or facing brick; it’s not mentioned at all.
Annabella schrieb:
Aerated concrete block (H+H) 17.5 cm (6.9 inches),
- Mineral wool insulation (KD) 12 cm (4.7 inches) (thermal conductivity class 035),
The total wall thickness is approximately 45.0 cm (17.7 inches). Whether you prefer polystyrene or mineral wool, hollow bricks or aerated concrete, is not necessarily a matter of belief. Some would never build with aerated concrete, while others would never attach any polystyrene products to the house.
If a wall construction like the one mentioned were of higher quality overall (let’s set aside the facing brick for now), you would surely see this reflected in the house price. Nobody gives anything away—both construction companies are in the affordable segment.
By the way, although not asked, a branded facing brick does not necessarily mean it is of high quality. And TM has repeatedly attracted negative attention at the start of house construction due to its no longer available “brands,” while Heinz von Heiden also has its shortcomings. Which is of higher quality?
Annabella30 Jan 2024 19:3311ant schrieb:
Have you also considered KB Brandis or Mein Haus (in Nauen, with whom, as far as I know, @motorradsilke and @Nida35a have built)?Thanks for the suggestions, we will take a look. (Creditworthiness is currently a key factor; in this regard, TMH and Heinz von Heiden have an important advantage.)A
Annabella30 Jan 2024 19:34ypg schrieb:
A weatherproof facade design is completely missing here, whether it’s plaster or cladding, it’s not mentioned at all.Thank you, at Heinz von Heiden it is a plaster variant.A
Annabella30 Jan 2024 19:3711ant schrieb:
No significant other differences can be identifiedVery detailed regarding specifications/scope of work and comparable. Therefore, this is now exclusively about the wall construction mentioned here. Thank youSimilar topics
