ᐅ Wall construction for KfW 40 standard (monolithic or with external thermal insulation composite system) for a single-family house
Created on: 24 Dec 2025 06:44
MarkusbaHello experts,
with our new bungalow construction project, we are still undecided about the wall structure (here only wall structure for KFW40).
Originally, we were planning: Poroton + ETICS (external thermal insulation composite system). After initial discussions with the shell builder, he recommended considering a monolithic wall structure.
Therefore, I would be interested in your opinions on this.
The U-value is almost identical; the costs seem to be slightly lower for the monolithic structure (prices are from websites: hopefully they are somewhat accurate!).
In single-family house construction, I mostly see a monolithic wall structure.
Thank you 🙂
Thank you 🙂
| | Poroton T16 42.5cm (17 inches) + Hasit 242 (light plaster) | Poroton T14 24cm (9.5 inches) + EPS 20cm (8 inches) | |
| U-value W/(m²K) | 0.13 | 0.12 |
| Material costs /m² | 160€ for Poroton + 30€ for mortar | (60€ for Poroton + 30€ for mortar) + (30€ EPS + 30€ mortar) |
| Labor costs /m² | 80€ for Poroton | 80€ for Poroton + 70€ for EPS |
| Total | 270€/m² | 300€/m² |
| Advantages | - higher sound insulation - simpler construction (fewer trades involved) → less prone to errors - lower tendency for algae/mold growth - easier connections (windows, etc.) - easier to plaster - more impact resistant | - better thermal insulation |
| e.g. from Schlagmann or Wienerberger including a good range such as load-bearing insulation, window fastening reinforcement) |
Markusba schrieb:
After initial discussions with the structural builder, he recommended considering a monolithic wall construction. I have nothing to add to my stone mantra; it remains valid unchanged.
nordanney25 Dec 2025 11:37Markusba schrieb:
So I would be interested to hear your opinions on this.I don’t really care about the wall construction itself. What matters is the final result. (If I had to choose, I would rank cavity walls, monolithic construction, and then ETICS in that order. If price were the factor, it would be exactly the other way around. My recent houses were brick veneer, brick veneer, and currently ETICS—but with rigid phenolic insulation because it doesn’t require such thickness.)And the prices you mentioned can be ignored. It’s the internet and has little to do with real prices. If your shell builder, who normally constructs monolithic walls, has to hire a team specialized in ETICS, it will be more expensive (and more prone to errors). And vice versa.
