ᐅ Floor screeding contractor leaves piles of sand. Should this be tolerated?
Created on: 2 Sep 2018 17:43
sco0ter
after our screed was laid, there is now a relatively large area of sand directly in front of our house entrance, estimated at about 15-20m² (160-215 sq ft). It’s less of a pile and more of a flat surface.
Apparently, our (anhydrite) screed was made using this sand, because it looks sandy as well.
What annoys me:
1. All the sand is now lying on the lava stone we paid a lot for.
2. The sand gets tracked into the house.
3. If it rains, it will get even muddier.
Point 1 annoys me the most because I’m worried the sand might seep down to the basement wall, holding moisture that then presses against the wall. The site manager specifically recommended lava stone to ensure good water drainage.
Questions:
- Should I be concerned about this?
- Why would the workers leave all the sand there? Are they unwilling to remove it?
- Is this normal?
- Could the sand cause problems with moisture on the basement wall underneath?
Thanks!
Nordlys
2 Sep 2018 21:56
What else can they do with the sand? Spread it nicely; grass likes a bit of sand in the soil.
2 Sep 2018 22:01
Sand is not dirt, and it is not garbage.
You are having a house built, so this is a construction site...!
It can happen that sand is lying around “somewhere” or wherever. Even on a driveway or other surfaces.
I really cannot understand or relate to a homeowner being bothered by sand residues. Well, we do have a church in the village 😉
Curly
2 Sep 2018 23:26
We are currently using the sand to set our fence posts in concrete, so it can definitely still be put to good use.
Sabine
sco0ter
3 Sep 2018 00:00
Ok, thanks for your feedback.
It doesn’t seem to be that bad after all...
As for the question of what else they should do: yes, just take it back and use it for the screed at the next construction site.
HilfeHilfe
3 Sep 2018 06:56
So it doesn’t seem to be that bad after all...
But regarding the question of what else they should do with it: Yes, just take it again and use it for the screed on the next construction site.
TOO complicated! Sand costs nothing.
Bookstar
4 Sep 2018 22:55
Seven times seven is fine sand!
