ᐅ The parquet flooring under the office chair is lighter in color. Can parquet wear down from use?
Created on: 2 May 2023 18:21
Star_trek300
Star_trek300
2 May 2023 18:21
I use my office chair a lot on the hardwood floor. There are no scratches on the floor, but the area has become lighter than usual. Possibly some rubbing? Is there anything that can be done about this?
I didn’t know that office chairs should be placed on a floor protector to preserve the hardwood.
Jaden Hoch
Scout**
2 May 2023 19:20
First, the type of chair casters matters. Second, you will have a colored oil on the parquet floor, which you apply slowly using the casters. Ask the manufacturer which oil was used and then apply a very thin layer with a cloth.
werwurm
20 Sep 2023 19:58
When chairs are constantly pushed back and forth, they leave marks on the floors. This is not only annoying but can also lead to conflicts, especially when using a rental property. Chair socks could be a solution. Chair socks are simple but highly effective ways to prevent scratches and marks on floors. They also reduce annoying noise. Perhaps this could be a solution.
kati133720 Sep 2023 20:23
werwurm schrieb:
When chairs are constantly moved back and forth, they leave marks on the floor. This is not only annoying but can also lead to conflicts, especially when using a rental property. Chair socks could be a solution here. Chair socks are simple but highly effective ways to prevent scratches and marks on floors. They also reduce annoying noise. Maybe this could be an option.
Chair socks... on an office chair? ....
We have now switched to XeloTech, which are rubber skate wheels. Also because of the hardwood floor. Whether they will work well in the long term remains to be seen. At the moment, they just annoy me because they roll so easily that I keep moving somewhere against my will.
X
xMisterDx
21 Sep 2023 21:15
Ownership or Renting? With ownership, I’d probably just think “that’s how it is.”
You don’t lay down hardwood flooring only to cover it up with cheap plastic, also known as floor protection, just because of the office chair...
There is no wear-free movement. Especially with an office chair, since the wheels are always under load when rolling around. Over time, this inevitably wears away the finish and/or even the material itself.
Buchsbaum
22 Sep 2023 16:17
How old is the parquet flooring and what type of wood is it?
Basically, this only partly depends on the chair. Parquet darkens significantly due to UV light, depending on the type of wood.
Over time, it darkens evenly, except in areas where no light reaches or where the UV exposure is filtered.
Therefore, it is possible to have lighter spots under tables, cabinets, floor protectors, and similar items.
I have Doussie wood parquet throughout the house, which darkened quite a bit. This process lasted up to 6 months. Under the bed in the bedroom, it is still visibly lighter. But after all, it is a natural product.
