ᐅ Terrace Shading – Roof Covering, Awning, and More
Created on: 6 Feb 2024 09:12
Prager91
This year we want to progress further with our garden planning, and the topic of shading has come up.
Since we also have a small child, shading has become important to us.
We have a newly built house and are now entering our third summer – we’re getting tired of using two €50 (about $55) umbrellas as our only shading solution.
We have a terrace that is 4 meters (13 feet) deep and 8 meters (26 feet) wide, facing south. The sun shines directly on the terrace all day long.
So far, we haven’t looked much into the pros and cons of different shading options, but we definitely want to tackle this “project” this summer.
--> We don’t need to sit outside in the rain, so a fixed, permanent roof is NOT necessary.
--> We have/want weatherproof furniture that can stay outside uncovered even in light rain, so again, a permanent roof isn’t required here.
--> It’s quite windy where we live, so some kind of side protection would be nice, but that might be too expensive for us right now.
--> We want a future-proof, long-term solution, but ideally also a cost-effective option.
At the hardware store, you often see “cheap” patio roofs – so the question is: are these any good?
What do you think about an awning? We’re not opposed to that, as our main focus is on shading.
Regarding sun sails: we haven’t looked into these yet, but we increasingly see them in our new housing area. Are they weatherproof? Can you leave them up all year? The disadvantage seems to be that they’re permanently stretched, so you can’t let the sun in sometimes, right?
In the end, I’d just appreciate some input and maybe some of your personal experiences. Surely some of you have already tackled this project and can share your thoughts.
Thanks!
Simon-189
9 Feb 2024 08:19
Prager91 schrieb:
I do wonder, though: How does wall mounting work with such a roof regarding the roller shutter box? Is it feasible?
Attaching a roof to the roller shutter box won’t work. The outer shell is usually only 15-20mm (about 0.6-0.8 inches) thick, so you shouldn’t fix anything to it.
It is only possible to attach directly to the concrete slab or the masonry underneath or above, depending on the wall construction.
Prager91
9 Feb 2024 08:27
Simon-189 schrieb:
Attaching a roof to the roller shutter box won’t work. The outer shell is usually only 15–20 mm (about 0.6–0.8 inches) thick, so you can’t fix anything to it.
This is only possible directly into the concrete slab or the masonry beneath or above. It depends on the wall structure...
Ultimately, the willow pavilion has a height of 255 cm (100 inches).
The rough construction height of our masonry is also 255 cm (100 inches).
So, the question naturally is, how high are the roller shutters installed.
