ᐅ Patio Door: Swing Door, Lift-and-Slide Door, or Parallel Slide-and-Tilt Door?
Created on: 18 May 2015 07:39
kernm23
What do you recommend for a patio door?
Swing door, lift-and-slide door, parallel sliding-tilt door.
Width: approx. 2 m (6.5 ft)
What would be the clear opening width for sliding doors with a total width of 2 m (6.5 ft)?
Alex85
24 Jul 2018 17:54
W8ne3 schrieb:
which glazing, plastic/aluminum-wood?, safety glass? ...
Glazing: usually triple glazing. For thermal insulation requirements, your architect or energy consultant will advise you what is needed. Special features like soundproofing are up to you and may also be specified by the local zoning plan.
Material: according to personal preference and budget.
Safety glass: depends on your personal safety requirements and, again, your budget.
W8ne3
24 Jul 2018 18:03
There’s no such thing as a double door without a mullion, right?
What do you think about folding doors?
11ant24 Jul 2018 19:18
Alex85 schrieb:
Not everyone likes the mullion and it can sometimes create a "requirement" to add even more mullions to keep the appearance consistent.
Funny reasoning – especially in connection with the suggestion
Alex85 schrieb:
Asymmetrical. 1/3 fixed, 2/3 opens.
Do you then make several elements asymmetrical as well?
In this case, you would have one sash that protrudes more – but on the other hand, a comfortable clear opening width with only one opening sash.
W8ne3 schrieb:
A French door without a mullion doesn’t exist, right?
Of course it does, with a “board in front of the head,” meaning: a post in the middle.
Not suitable at this width.
Alex85
24 Jul 2018 19:35
Funny reason
Yep, that would be something different.
Of course, with a "board in front of the head," meaning: a post in the middle.
Or simply no double door, but with a portion (distributed however) in fixed glass.
A post in the middle is absolutely not acceptable.
11ant24 Jul 2018 19:42
Alex85 schrieb:
A post in the middle is definitely not an option.
Having a post in the middle mainly means that both passages are equally narrow, so aside from variety, the second one doesn’t offer any additional benefit.
