ᐅ Smart Home Experiences with Philips Hue and Somfy TaHoma
Created on: 24 Nov 2021 10:45
Nixwill
Over the past few years, I’ve gradually made our rental apartment a bit smarter. Tado for heating and air conditioning, Hue for the lights, Nuki for the front door, Eve for the garden, some smart plugs and window sensors, and Netatmo to stay informed. Everything is integrated with Apple’s HomeKit, and almost everything can also be controlled via multiple Alexas.
Overall, we are very satisfied with our setup. So far, we have no problems running automations that, for example (where desired), turn on the lights via motion sensors. Geofencing controls many things (cameras, heating, lighting, etc.), so for us, almost all needs are covered. Since we already have a lot of hardware, we want to keep all of it and implement it in our new house. Of course, there are also some things to improve here.
Just this past weekend, I discovered that Philips has a collaboration with Gira offering switches that require no wiring, no batteries, and look great as well. Although we enjoy almost everything automated, there are always some situations or rooms where a simple switch is still faster and better. That’s why we are currently considering installing these switches alongside the existing wired light switches where they already sit. Weberhaus also offers this solution for their houses, so it can’t be too bad. Still, it would be quite a drastic step to completely give up the “old” switches and thus wiring as well.
Here is question 1:
Who has already implemented this solution with the Hue switches and can share their experience?
I have, of course, imagined some worst-case scenarios and have tested a few things at home. Lights MUST always be able to be turned on somehow—that is my basic requirement.
Case 1: Internet connection fails (Wi-Fi still active).
Apple HomeKit is offline, as is Alexa (both perfectly manageable since these are luxury features, not basic requirements). Hue devices still communicate and can be controlled both with the switches and the app.
Case 2: Router (FritzBox) total failure.
Same as Case 1.
Case 3: Hue Bridge breaks.
Lights can no longer be controlled by either the switches or the app. BUT the emergency solution still works: cutting power to the lamp and restoring it. Hue bulbs are, by default, ALWAYS on when powered.
The catch with the new Gira switches is that they also stop working, meaning you really have to remove the bulb and put it back. For me, that’s okay in such an exceptional situation—it has never happened to me in all these years, and one night can be managed like that.
So, the Hue solution with their switches is basically acceptable to me even in an emergency. Test passed!
Please point out any cases I haven’t thought of (and please don’t just say power outage 😀).
Now, as a new feature for my new house, I will have roller shutters everywhere, which will be controlled wirelessly with Somfy motors, so I need your help again since I can’t test these yet.
The question here is: are there wireless solutions that allow the roller shutters to be lowered even in exceptional situations?
Theoretically, radio motors don’t need switches anymore, but are there similar wireless switches that require no wiring?
What’s really important to me is: if all standard equipment fails (the associated bridge, Wi-Fi router…), is there any way to still lower the roller shutters without installing a wired backup solution?
That’s it for now 😀.
A quick clarification: I’m just a user, so if I have described things incorrectly (like calling a switch a button or vice versa—I’ve never been able to keep that straight), please overlook it 🙂
From a smart home enthusiast who doesn’t really have a proper smart home yet 😉
Patricck1 Dec 2021 22:01
I’m not really impressed with Somfy either. I get the impression their system is somewhat outdated.
There are more innovative manufacturers that offer more than just rolling shutters and similar functions.
Have a look at Loxone to see if that suits your needs. Wireless is always an option when no other solution is possible.
Araknis1 Dec 2021 22:32
Nixwill schrieb:
Would you like to mention some much better solutions? Then I can look into them.
Just standard motors combined with actuators of your choice. But avoid proprietary motors that only work with a specific wireless system controlled by a completely isolated control unit. Ideally, a central actuator system is best, but there are also good options in decentralized setups. Opus, Shelly, or similar...
In general, this applies here:
Patricck schrieb:
Wireless is always a solution when there’s no other way.
… or when you forgot something.
Nixwill1 Dec 2021 22:43
By "normal motors," do you mean wired ones? What is a proprietary motor? And what do central and decentralized mean?
Where would the Eltako 64 devices I mentioned belong?
Nixwill1 Dec 2021 22:47
@Patricck
I don't think I can freely choose the manufacturer now if I decide to go with Roma for the external blinds…
Araknis2 Dec 2021 11:57
Yes, normally these systems are wired. Proprietary means, for example, that you cannot simply connect Somfy motors to a generic roller shutter actuator without workarounds; you have to stay within the Somfy ecosystem. Centralized means that all motor cables are routed to the electrical distribution panel, where the actuators are installed. Decentralized is similar to classic wiring, meaning the motor’s power supply runs through the switch to the motor. Instead of the switch, decentralized actuators could be used. All of this needs to be clarified before the electrical installation.
Your roller shutter installer will advise you on which motors you can use. Choosing a simple, “dumb” motor without smart features will give you greater flexibility.
Nixwill2 Dec 2021 12:17
Okay, so I can’t go wrong if I just say I want the wired solution, right? Even if the motor is from Somfy?
And can you maybe tell me more about this?
Nixwill schrieb:
... the wired solution and then controlling it with devices like the ELTAKOs? It sounds like you could (if you wanted) install a switch and still use a fully wireless system. Plus, you wouldn’t have the range issue since, as I understand it, it would then work over Wi-Fi.
Is that correct? Can I, for example, connect this Eltako 64 to that wired motor? Are you familiar with these Eltakos?
