ᐅ Roller shutter without a stopper – what is the technical term?
Created on: 20 Oct 2022 10:02
JaiBee07
JaiBee07
20 Oct 2022 10:02
I happened to notice a item in my window quote called a stopper.
After some research, I found out that these are very ugly parts fixed on the outside of the roller shutter, used to detect the end position for the motor. Apparently, the motor recognizes it has fully closed by the increased torque.
I definitely don’t want these ugly parts on my roller shutter. However, there seem to be other solutions without stoppers.
What should I include in a request for quotation to make it clear to the supplier? Something like “electronic end position detection”?
In der Ruine20 Oct 2022 11:01
The stoppers are only designed for manual operation using a cord. For motorized roller shutters, you do not need anything like this.
JaiBee07
20 Oct 2022 11:10
How confident are you in your statement?
I have definitely read that some roller shutter motors (e.g., Somfy Ilmo) detect their end positions by increased torque. When closing, they recognize it when they hit the frame, and when opening, when the stoppers engage.
And my offer also included electric roller shutters. So I’m not entirely sure about that.
In der Ruine20 Oct 2022 11:17
The roller shutter stopper is only there to prevent you from manually pulling the shutter curtain completely into the housing.
Electric roller shutters should generally have adjustable end limits, at least when the window and shutter curtain are supplied together. I’m not entirely sure how this works with retrofit roller shutters.
SaniererNRW123
20 Oct 2022 11:17
JaiBee07 schrieb:
And my quote also included electric roller shutters. So I’m not that sure about it.
Standard roller shutter motors (mechanical roller shutter motors) have fixed adjustable end positions. Beyond that, there are electronic roller shutter motors. With simpler versions, you can set the upper and lower end points by pressing a button, and the devices also feature obstacle detection and blockage protection. More advanced are "self-learning" motors with fully automatic end point setting and monitoring.
Of course, the price increases accordingly.
JaiBee07
21 Oct 2022 09:50
Ok, thanks for the feedback.
It’s just a bit strange since this is an offer for windows including electric roller shutters, not a separate retrofit.
Perhaps this is a characteristic of the Somfy Ilmo motors included in the offer.
It seems that without a stopper is more of a standard and does not need to be specified separately.
