ᐅ Single-family house without a basement – creating additional usable space elsewhere
Created on: 26 Mar 2018 14:43
EnnoBecker
We are building our single-family house without a basement with the following specifications:
Gable roof with a 45° pitch
Knee wall 1m (3.3 ft)
Living area: 148 m² (1,593 sq ft)
House dimensions: 8.95m x 11.32m (29.4 ft x 37.2 ft)
We want to compensate for the lack of storage space from the missing basement through the following measures:
I have questions regarding the following points:
1 - Attic:
This is a cold roof, meaning the floor between the upper floor and attic is insulated with mineral wool and has a vapor barrier in between.
The goal is to create more storage space. The attic is not intended to be used as living space.
For this purpose, I want to use tongue-and-groove boards, as these are vapor permeable compared to OSB panels and therefore prevent issues with rising moisture from the upper floor.
Questions:
The attached picture is provided as an example.
2 - Garage
The garage is planned to be 3.45m (11.3 ft) wide and 9m (29.5 ft) long. Inside the garage, a partition wall will be installed to separate the parking space from a storage area. Do you have recommendations for manufacturers or personal experience with this?
Thank you for your help.
Enno
- Make the attic accessible
- Build an extended single garage
- Build a spacious garden shed
1 - Attic:
Questions:
- So far, a pull-down attic ladder is planned. My wife prefers a fixed space-saving staircase with a railing for easier access. In my view, this should be no problem as long as the access hatch to the attic remains insulated. Are there suitable solutions for this?
- We would also like to dry wet laundry in the attic. In our case, is this unproblematic? I believe the evaporated moisture could easily escape.
- What do you think, how much effectively usable floor area would this create?
- Do you have any personal experience with this?
2 - Garage
Enno
Our ventilation system is planned for the attic.
I built the ceiling from the attic space as follows:
Plasterboard
15mm OSB
200mm (8 inches) insulation with a thermal conductivity of 0.035 W/(m·K) between the collar beams
22mm OSB
The mechanical ventilation unit will be installed on the gable wall, with supply and exhaust air ducts routed at the gables.
Plasterboard
15mm OSB
22mm OSB
bortel schrieb:
Gypsum board
15mm (0.6 inches) OSB
200mm (8 inches) insulation with a thermal conductivity of 0.035 W/(m·K) between the joists
22mm (0.9 inches) OSB
. You have a wooden beam ceiling, right? We have concrete.
