ᐅ Single-family house with a small footprint, attic, and basement; neighbor approval required
Created on: 2 Oct 2015 13:52
sirhc
Some time ago, I shared hand-drawn sketches here for discussion. The biggest change since then is that I moved the entrance from the front to the side. I plan to review this design with a professional next week, but until then, I would like your help to identify and fix any potential weaknesses. A special feature is the significant deviation from the "square optimum," so many other interesting topics only helped me to a limited extent. Therefore, my question is: where are the major issues, what could I solve in a more elegant way, and of course, I’m also interested in what you find successful. Please excuse the pen and paper approach, but that’s how I work best on the design. Based on this, I will draw the basement, first floor, and attic over the weekend—unless the feedback turns out to be too negative.
We could build 3m (10 feet) deeper, but that would further reduce the already small garden, so we prefer not to. The roofed area in front of the garage probably requires the neighbor’s approval, right?
To the north is the access road (a dead-end street ending at our plot); to the south, behind the garden, runs a rail line for regional and freight trains (6 trains per hour during the day). The western neighbor built a long time ago; on the east side is a triangular plot currently covered with forest. We expect garages along the property boundary there, but a house probably won’t fit due to setback requirements.
Edit: very important — I know the windows are only partially shown. I’m still undecided about their arrangement on the east and south sides.
Development plan/restrictions
Plot size 372 sqm (front approx. 13.50m (44 feet), rear boundary beveled)
Slope none
Floor space ratio 0.4
Floor area ratio not defined
Building envelope, building line and boundary 7.50m (25 feet) wide x 15.00m (49 feet) deep, 5.00m (16 feet) setback to the street in front
Boundary construction House with 3.00m (10 feet) side setbacks each, garage on the property boundary
Number of parking spaces 3
Number of floors 1
Roof type gable roof or half-hip roof with 43° to 47° pitch
Architectural style not defined
Orientation not defined
Maximum heights/restrictions not defined
Other requirements not defined
Homeowner requirements
Style, roof type, building type classic, gable roof, solid construction, plaster finish
Basement, floors yes (basement, ground floor, first floor, attic)
Number of occupants, age 2 adults early 30s; 2 children planned
Space requirements on ground and first floors difficult to answer now; on the ground floor I have 56 sqm (600 sq ft) excluding stairs, which sounds small but looks sufficient
Office: family use or home office? no office
Overnight guests per year 10
Open or closed architecture open
Conservative or modern construction conservative
Open kitchen, cooking island yes, cooking peninsula
Number of dining seats 6-8
Fireplace yes
Music/sound wall no
Balcony, roof terrace no
Garage, carport yes, yes
Vegetable garden, greenhouse possibly, no
Other wishes/features/daily routine none
Who designed it do-it-yourself
What do I like most? openness from kitchen through dining to living area; central staircase connects all floors with minimal hallway/traffic space
What do I dislike? the limitation to 7.50m (25 feet) house width causes more problems than expected; doubts whether the central staircase in the living room will be a problem
Cost estimate according to architect/designer not yet defined
Personal price limit for house including fittings not yet defined
Preferred heating system air-to-water heat pump
If you have to give up something, which details/extras
-can you give up?
canopy/carport, possibly fireplace
-can you not give up? basement, garage
sirhc
Site plan with parcel numbers and blue outline of a building
Hand-drawn floor plan sketch of a house with kitchen, dining area, living room and garage.
sirhc5 Oct 2015 16:39
The dashed lines do not represent walls but only define the hallway-dining-living areas, which is how I calculated the spaces. These areas are intended to be completely open.
I’m missing the correct term at the moment, but the gable roof is positioned on the house in such a way that headroom is not an issue anywhere. In other words, the ridge runs from north to south, not from west to east. This also creates an attic space above the upper floor.
5 Oct 2015 17:44
...so, a cut-out terraced house?
kaho6745 Oct 2015 17:46
So, I didn’t mean the dashed lines either. That was already clear to me. No, I think the other interior walls are too thin. What is planned there? Our interior walls are 17.5cm (7 inches) thick if they are non-load-bearing. Otherwise, I believe they are 24cm (9.5 inches) thick. (Oh god, I’ve already forgotten everything again.)
Musketier5 Oct 2015 17:49
kaho674 schrieb:
So, I didn’t mean the dashed lines. That was clear to me already. No, I think the other interior walls are too thin. What is planned there? Our interior walls are 17.5cm (7 inches) if they are non-load-bearing. Otherwise, I believe 24cm (9.5 inches). (Oh god, I’ve forgotten everything again.)
You can tell you haven’t been around for a while 😀
17.5cm (7 inches) is enough. For non-load-bearing interior walls, 11.5cm (4.5 inches) also works.
Musketier5 Oct 2015 17:55
I just checked again. In some cases (e.g., for large spans), 24mm (1 inch) beams may also be necessary for load-bearing walls.
sirhc5 Oct 2015 18:18
kaho674 schrieb:
Well, I didn’t mean the dashed lines either.
Okay, then I’m not really sure what you meant by 45° walls.
I probably drew everything as non-load-bearing, but that probably won’t be possible in the end. 🙂
...so a cut-out terraced house?
Yes, you could call it that. 🙂
