ᐅ Should I indicate a semi-detached house when requesting information about a plot?
Created on: 8 Jun 2021 09:11
Z
Zinada1
Z
Zinada1
8 Jun 2021 09:11
Good morning everyone,
My partner and I are looking for plots of land. We have already contacted many municipalities and are on their waiting lists.
Now, a couple of friends got in touch with us—they would like to build a semi-detached house together with us.
So here is my question: Should we have mentioned the plan to build a semi-detached house when inquiring about the land? I find it a bit awkward if we were offered a plot and then come up with the idea of building a semi-detached house. Especially since some municipalities immediately rule that out.
U
user-d29
8 Jun 2021 09:26
Zinada1 schrieb:
I can imagine it would be awkward if you were able to get a plot of land
When you apply for a plot, you already know in advance what is allowed on that land (zoning plan / development plan). So it’s more awkward if you get the plot but a duplex is not permitted there. The local authority doesn’t care what you build. If you apply for a single-family home lot, you build a detached single-family house. If you apply for a plot suitable for a duplex, it’s obvious that you could also submit a building permit / planning permission application for a duplex then 😉
Zinada1 schrieb:
I can imagine it would be awkward if you were able to get a plot of land and then come around asking to build a duplex.
Only if the zoning plan says it’s not allowed there. Then everyone thinks: reading the zoning plan pays off.
i_b_n_a_n8 Jun 2021 09:41
The maximum number of residential units is often specified for municipal plots. In some cases, there is a requirement for duplex housing. Therefore, providing this information is usually mandatory but always advisable.
11ant8 Jun 2021 15:18
Zinada1 schrieb:
We have already contacted many municipalities and are on the waiting lists.
Now, a couple of friends have reached out to us; they would like to build a semi-detached house together with us.
My question is: should we have mentioned the semi-detached house option already when applying for the plot?
What do the development plans say about the plots you are on the waiting lists for?
Is the couple of friends in the same status as you regarding, for example, local resident priority points?
Basically, most newer development plans generally allow detached houses in some areas and semi-detached houses in others, meaning two adjacent plots with halves of a duplex joined on one side. Additionally, there is also the option to build a semi-detached house on one common, legally undivided plot—assuming it is suitably sized.
Clarify the following points: your size expectations and those of the couple of friends, as well as your basic views on having a basement (unless this is already determined by a sloped site). Plan together—even if one couple wants a masonry house and the other prefers a timber house. Especially if one couple plans to build with a basement and the other without, in my opinion, you absolutely need a joint coordinator.
