Hello, I need to install about 40 meters (130 feet) of sewage pipe. I would like to later use the base layer required for this for paving stones on a walkway. The path will run along a property boundary. How much distance do I need to maintain legally and technically from the neighbor for the pipe? In the end, there will also be 2 inspection chambers involved...
Keep at least 1 meter (3 feet) away from the bottom of the trench to be on the safe side. This is more related to the trench and possible soil slippage than to any required clearance.
Be careful with a 40-meter (130 feet) long trench along a road, as there are likely special safety requirements. It is best to consult with a local civil engineer or excavation specialist.
Since the wastewater pipe by definition must leave the property to function properly, you are generally allowed to lay it up to the property line. For example, we have a public sewer on our property boundary, but appropriate safeguards have, of course, been officially recorded for this.
