Berthold-130 Jan 2013 17:39Hello everyone,
There was a fire in our new build. During that, a water pipe burst and flooded the entire house with about half a meter (1.6 feet) of water 😡
The water penetrated through the walls and even came out through the brick joints on the outside. Quite a disaster. Now the question is whether the insulation needs to be completely removed or if I can leave it in place and let it dry? Naturally, drying it would be cheaper, but I’m not sure how to go about it.
My house is a timber frame prefabricated house, and the external insulation is made of "water-repellent" Rockwool "Fixrock VS".
MODERATOR1 Feb 2013 11:25Hello Berthold,
I am more concerned about moisture penetration in the wooden components. Mineral wool does not absorb water; in fact, the water-repellent type should not cause any problems in this regard.
If there is still water or moisture within the wall assembly, which I assume, it is, as mentioned, dangerous for the wood structure.
Drying should definitely be carried out by a professional company, especially for warranty reasons.
Have you already spoken with the insurance company? Would opening the wall (to allow proper drying) be covered by the insurance benefits?
Kurt1985-19 May 2014 09:21This is a nightmare for every homeowner. Renovation after severe water damage must be carried out by a professional company. The wall also needs to be opened up; otherwise, the entire effort is worthless.
Ricardo-120 May 2014 12:19This is also a sensitive topic and an expensive matter. I just hope the damage is covered by the insurance. The wall has to be opened up and then everything needs to dry out gradually. A professional company also has the appropriate equipment.
