ᐅ Repainting Kallax – Which Type of Paint Works Best?
Created on: 11 May 2019 08:37
Jofiteo
Jofiteo
11 May 2019 08:37
I am planning to repaint my IKEA Kallax shelf because I’m not completely happy with the color and want it to look a bit more personalized. However, I’m unsure which type of paint would be best for this.
The Kallax is made from particleboard with a thin melamine resin coating, which makes painting somewhat tricky. I would like to know if acrylic paints work well or if it’s better to use synthetic resin paints, what kind of primer is necessary, and whether special preparation steps (sanding, cleaning) are essential for a long-lasting result.
I’m also interested in how the durability and scratch resistance of the different paint types compare, so I won’t be disappointed later.
Has anyone had experience repainting Kallax or similar furniture? Which paints did you use, and were you happy with the results?
Looking forward to your recommendations and tips!
lochen
11 May 2019 09:42
Jofiteo schrieb:
The Kallax is made of chipboard with a thin melamine resin coating, which makes painting a bit tricky.
You’ve made a very good observation! The melamine coating is probably the biggest challenge when painting Kallax.
I always recommend first roughening the surface thoroughly – this works best with fine sandpaper (grit 220-320). It’s important not to sand too aggressively to avoid damaging the chipboard. Afterwards, dust off the surface well and prime it with a suitable adhesion promoter or primer. Special primers designed for melamine or plastics are helpful here.
After that, you can use either acrylic paint or alkyd (synthetic resin) paint. Acrylic paints are water-based and easier to work with, producing less odor, but sometimes they are not quite as durable as alkyd paints. Alkyd paints are solvent-based, harder, and more resistant, but have a stronger smell and require good ventilation during application.
For furniture that is used frequently, I usually recommend alkyd paint because it offers better scratch resistance and durability.
Good luck with your project!
Gilbert
11 May 2019 10:18
lochen schrieb:
For furniture that is used frequently, I usually recommend synthetic resin paint because it offers better scratch resistance and durability.
Interesting, but honestly, I think this is somewhat overrated. Sure, synthetic resin paint is harder, but in more budget-friendly projects, I’ve had much better experiences with good acrylic paint than with the smelly and difficult-to-apply synthetic resin paints.
If you prime carefully and apply several coats, acrylic paint is more than sufficient and has the advantage of being easier to touch up. And who really paints their furniture piece daily?
Besides, I wonder if repainting a Kallax cabinet isn’t more about enjoyment and appearance, where the easier handling of the paint is more important than the marginally better protection.
So don’t let durability concerns confuse you too much—choose the paint that you find more pleasant to work with.
Jofiteo
11 May 2019 13:29
Gilbert schrieb:
If you prime carefully and apply several coats, acrylic paint is definitely sufficient
That brings me directly to the next point: How important are multiple coats? Do you think two coats of primer followed by two or three coats of paint are enough, or should one apply more layers to achieve a truly durable surface?
lochen schrieb:
Adhesion primers for melamine or plastics are helpful here
Can you or anyone else provide specific product names or at least details about these primers? I bought somewhat at random at the home center, which probably wasn’t ideal and didn’t adhere well.
Thanks for the advice!
Giagau
12 May 2019 07:51
I will briefly address the question regarding the paint system and the products:
In my experience, two coats of a high-quality adhesion primer are sufficient to properly prepare the melamine surface. After that, applying 2 to 3 coats of paint is optimal. Between coats, a light sanding with very fine sandpaper (grit 320 or finer) improves adhesion and removes any unevenness.
Regarding the products:
- For priming, special adhesion promoters based on acrylic or polyurethane (PU) are suitable. These can be easily found at specialist suppliers, for example ‘Isoliergrund 518’ by Brillux or ‘Nexus Multi-Grund’ by Nexa.
- For the paint, I recommend a 2-component PU paint specifically designed for furniture or plastic coatings. These paints are very durable, chemical resistant, and scratch resistant.
Alternatively, a high-quality acrylic paint combined with an adhesion primer is a good solution if odor and environmental considerations are important.
Thorough degreasing of the surface with an appropriate cleaner is also essential, as dirt or grease can significantly impair adhesion.
I hope this helps!
