ᐅ Reducing Assembly Time for BILLY Shelving – Practical Tips
Created on: 17 Aug 2022 19:34
Mido56
Mido56
17 Aug 2022 19:34
In this thread, I would like to focus on ways to effectively reduce the assembly time for the BILLY shelf unit from IKEA. I find that putting it together often takes longer than necessary, especially if you are not experienced or not optimally prepared.
I am interested in which practical aids, tricks, or tools you use to save time without compromising safety or stability. Are there any helpful sequences or preparation tips that should be considered? I believe firsthand experiences and concrete suggestions are very valuable here.
Looking forward to your answers and ideas!
Hannah
17 Aug 2022 20:12
I would recommend laying out all the parts sorted and organized on a large table or on the floor before assembly. This way, you don’t have to keep searching.
A cordless drill with the appropriate bit also saves a lot of time compared to using a screwdriver.
klo40
18 Aug 2022 08:46
to reduce the assembly time of the BILLY shelf, I highly recommend considering the following steps before starting:
1. Check and sort all parts: Verify all wooden panels, screws, dowels, and fittings against the instructions. Mistakes in identifying parts can cost a lot of time later.
2. Prepare tools: Besides a cordless drill, it’s useful to have a small hammer, a screwdriver, and possibly an Allen key if you don’t have one.
3. Prepare the assembly area: A large, flat surface is important. A blanket or protective mat will prevent scratches on the materials.
4. Follow the steps carefully: Avoid trying to do several steps at once. Read the official instructions thoroughly. Especially the order in which parts are assembled makes a big difference.
If you build the shelf with a second person, it’s helpful if one person holds the parts while the other fastens them. This saves time and makes the assembly safer.
In summary: Good preparation, the right tools, and strictly following the instructions are the key success factors. Mistakes, like overtightening screws in the holes or installing parts upside down, waste unnecessary time, so: being careful also saves time!
I hope these tips help you and others here.
Wesley
19 Aug 2022 15:27
klo40 schrieb:
If you assemble the shelf with a second person, it’s a good idea for one person to hold the parts while the other screws them together.
Exactly! Having a second person can really make a difference—especially just for holding the long sides.
Also: use a cordless drill with adjustable torque to avoid stripping screws or damaging the material. Before starting assembly, I always put all the parts into small containers, like a kind of parts organizer, so you don’t have to waste time searching. And of course, don’t forget coffee and a good mood—that helps too ;-)
