ᐅ Screwing in shelf screws without over-tightening.
Created on: 4 Oct 2016 08:42
Kimo60
Kimo60
4 Oct 2016 08:42
I recently bought a Billy bookshelf from IKEA and now face the challenge of tightening the screws properly without over-tightening them. I understand that over-tightening the screws on this model can damage the wood and affect the stability of the shelf. Unfortunately, I haven’t found clear guidance on the recommended torque or procedure to safely tighten the screws enough without causing damage.
Does anyone have experience or tips that could help me screw them in correctly while protecting the material? Are there specific techniques or tools you would recommend for the Billy bookshelf to avoid over-tightening?
I appreciate any helpful advice!
LENNAU
4 Oct 2016 09:15
Hello Kimo60,
your question is really well asked, especially since shelves like the Billy have fairly thin wood and it’s easy to overtighten the screws. Generally, I recommend starting by screwing in the screws by hand to position them correctly. Then, set the drill or cordless screwdriver to a low speed.
Another tip: if you’re using a cordless screwdriver, you can reduce the torque setting. This way, the clutch engages early and prevents overtightening. When screwing manually, just work carefully and feel when the screw is tight.
It’s important not to apply too much force but rather to proceed patiently and tighten the screws incrementally with regular checks. Hope this helps!
dota57
4 Oct 2016 09:48
I would like to add that many people underestimate how important the right screwdriver is. For a Billy shelf, you should definitely use the correct bit that fits well into the screw head. A bit that is too small or too large increases the risk of damaging or stripping the screw.
When using a cordless drill/driver, the torque setting is crucial. I recommend choosing the lowest setting on the tool and driving the screw in very slowly at first. When it’s properly seated, you will hear or feel the resistance increase — that’s when you should stop.
Additionally, the original screws are usually connected to a plastic wall plug in the shelf. Once the plug starts to rotate, you should stop, as this is usually a sign of over-tightening.
In short: the right tools, low torque settings, and gentle handling — that’s the way to go.
ritotar
4 Oct 2016 10:12
Hi Kimo60 and all other DIY enthusiasts! 🙂
I find that driving screw-in shelf supports (also known as dowel screws) without over-tightening is a kind of small meditation exercise for home projects. Don’t turn too fast, add a bit of feel, and you can really sense how the screw behaves.
By the way, it sometimes helps me to lightly coat the screws with a bit of wax or soap on the threads. This way, they slide in more easily, and you don’t have to apply as much pressure.
And above all: No rocket launches with the cordless drill, but gentle insertion instead. Your wood will thank you! 😉
Leland
4 Oct 2016 10:37
Cordless screwdriver set to the lowest torque setting, initially screw in the screw by hand. If the anchor begins to turn, stop immediately.
LAYNE
4 Oct 2016 11:05
Take it easy! 🙂
One trick I often use: I always do the last turn by hand. This gives you the best feel for when the screw is properly seated and prevents over-tightening.
Also, the drill often makes a slight creaking or creaking sound when over-tightened, which you can hear when the wood gives way – stop immediately then, or you’ll have trouble.
