ᐅ Protecting BILLY Shelving During Transport – Tips and Tricks
Created on: 21 Dec 2024 10:17
Dabepe
Dabepe
21 Dec 2024 10:17
I’m planning to transport my BILLY bookshelf from IKEA soon and I’m unsure how to best protect it from damage. Specifically, I’m concerned about how to effectively protect the panels (especially the large back panels and side panels) to prevent scratches or breakage during transport.
Does anyone have experience with the best way to pack this type of bookshelf? Are there specific materials or techniques that work well for such delicate wood components? I’m also interested in how you secure the bookshelf during transport to prevent shifting and related damage. Is it better to completely disassemble the shelves, or can they be moved fairly safely assembled?
I’m looking forward to your tips and tricks, including any advice that might not be immediately obvious. Thank you in advance!
Davidleo
21 Dec 2024 10:45
That’s great that you’re planning to transport a BILLY bookshelf! 🙂 I did the same last year and can share some very useful tips. What worked best for me was to first remove all the shelves and, of course, fully disassemble the bookshelf. The back panel is quite delicate, so I packed it between thick cardboard sheets and then wrapped it with stretch film.
I also placed foam or blankets between the disassembled parts to keep everything protected from shocks. Then I secured everything tightly in the van with ratchet straps to prevent any movement during transport. This really gives you peace of mind!
Give it a try—it makes a big difference! Good luck with the transport :-)
Kinbu
21 Dec 2024 12:03
Hello Dabepe,
to answer your question as thoroughly as possible: It is definitely advisable to completely disassemble the BILLY shelf unit.
The back panel is usually the thinnest and most fragile part, so it should be transported as flat, protected, and crease-free as possible. It’s best to use sturdy cardboard or protective film for this. Then you can protect the other parts with blankets, bubble wrap, or foam.
When securing the parts in a car or van, it’s recommended not to leave them loose but to tightly fasten them with straps so they don’t shift even during sudden braking.
If you can’t fully disassemble the shelf, at least remove the shelves and secure the back panel especially well.
Could you please provide more details about the size of the shelf and the type of vehicle you are using? Then I can give you more specific advice.
Palenar
22 Dec 2024 09:38
Hello Dabepe,
I would like to follow up and provide you with a comprehensive guide on how to transport your BILLY shelf without causing any damage. The protective measures start already during disassembly:
1. Complete dismantling: Take the shelf apart completely to minimize the risk of cracks or deformities, especially with the back panels.
2. Protection of back panels: These are often thin and fragile. Place them between several sturdy cardboard sheets, or even on a solid plywood board to increase stability. Then wrap everything with stretch film.
3. Protection of side panels and shelves: Wrap them with thick blankets, preferably ones without rough seams or zippers, as these can scratch the wood. Alternatively, you can use foam sheets.
4. Packaging material: If available, bubble wrap is excellent, but not absolutely necessary if you have sufficiently thick blankets or foam.
5. Securing during transport: Lay the parts flat, stacked on top of each other, and secure them with ratchet straps. Make sure there are no hard objects between the wood pieces that could create pressure marks.
6. Means of transport: A covered van provides the best protection, shielding the shelf from weather and other external influences.
7. Consider the weight: BILLY shelf parts are relatively light but can be large when combined – it’s best to work with two people to prevent the panels from falling or bending.
One more question: Will your transport be rather short (within the city) or over longer distances? Depending on this, the protective measures can be expanded or simplified.
I hope this detailed guide is helpful for you. If you like, feel free to write which materials you have available.
