ᐅ Programming heating settings for nighttime hours
Created on: 15 Mar 2018 22:50
Mizit
we have a somewhat complex problem and are currently unsure about what to do. Any experiences would be appreciated.
Our house is 23 years old, with a Buderus boiler and control system; the burner was recently replaced. In our living room, there was a kind of "thermostat" that was already broken when we bought the house. We naïvely accepted the sales advisor’s statement that it wasn’t needed and assumed that the heating could be controlled directly at the unit downstairs.
We suspect that something was set up about 23 years ago, after which no one cared about this thermostat, and eventually, it just broke. The water may be a bit cooler, and our bathroom radiator never really gets warm despite bleeding and unblocking. Otherwise, everything is fine for us. When my husband goes into the living room around 7 a.m., it’s still a bit cool, but absolutely okay, and when I come home in the afternoon, it’s warm in there. So far, so good.
Now, we have rented out our granny flat to a young woman for 8 weeks. There is only one heating circuit. Due to her work, she gets up at 4:30 a.m. This was not a problem before, but since last weekend it seems that the flat is freezing cold when she gets up in the morning. Previously, according to her, this was different, and the heating was running in the morning. Now it isn’t anymore. She feels cold and wants this changed, which I can understand.
Today, a technician was here. The problem is: this control unit is broken. The heating is set to something, the sensor is located outside on the north side, but exactly what was set can no longer be read or changed.
The young woman now wants the heating to be set so that it is warm at 4:30 a.m.
Because we have only one circuit, we cannot separate the systems for the granny flat and the main house. This means we would have to set it so that the radiators start heating at 4:30 a.m. for ourselves as well. This makes no sense for us—no one here gets up before 6:30 a.m., the children get up about an hour later, and we may not be as sensitive to cold.
But to do this at all, a new controller is needed. These parts from 25 years ago are no longer available today—you can get “refurbished” ones from various online shops for around 300 euros, but whether we can still set those ourselves is questionable.
The alternative would be a completely new heating control system, which would cost about 1500 euros; a binding offer will be made. That is certainly even more expensive 🙂
For us personally, everything is basically fine, so this is a lot of money. On the other hand, it may also not be very sensible if you have no way to adjust your own heating, and sooner or later, one might have to invest in this anyway?
Caspar2020
27 Mar 2018 16:19
Mizit schrieb:
Hmm, good question. Does it have to be indicated on it?
At least the model number, etc., should be in the manual or technical specifications. A quick search online usually helps.
If this is old technology, then the following applies to you:
Mizit schrieb:
Are we then exempt?
Not based on the existing building regulation, because the Energy Saving Ordinance states:
For residential buildings with no more than two units, where the owner occupied one apartment on February 1, 2002, the obligations under paragraphs 1 to 3 only apply in the event of a change of ownership after February 1, 2002, to the new owner. The deadline for fulfilling the obligations is two years from the first transfer of ownership.
In other words, only if your boiler is either of the following:
  • A low-temperature boiler: a heating boiler that can continuously operate with an inlet temperature of 35 to 40°C (95 to 104°F) and where under certain conditions condensation of the water vapor contained in the exhaust gases may occur.
  • A condensing boiler: a heating boiler designed to condense most of the water vapor contained in the exhaust gases.
Otherwise, according to the current Energy Saving Ordinance, replacing your boiler is mandatory by 2025.
Mizit
27 Mar 2018 16:39
I just went down to check again. The term condensing boiler or anything like that is not indicated anywhere.
Heating boiler according to DIN 4702
Type G115-21
Manufacturer number 08186055-02-015830
Construction type number 06-226-352
DIN registration number 3 R 054/92
Heat output 17-21 kW
Heat load 18.4-23.0 kW
Nothing is specified for the steam drum type
Joedreck
27 Mar 2018 17:46
If it is controlled by the outdoor temperature after the conversion, it is not a constant temperature boiler. That means you do not need to replace it. Don’t let that confuse you.
Mizit
27 Mar 2018 18:03
Do you mean by conversion the replacement of the controller?
But even if we don’t “have to”: isn’t there a high risk that a 23-year-old boiler will eventually fail on its own?
Caspar2020
27 Mar 2018 18:27
Joedreck schrieb:
If it is controlled by outdoor temperature after the conversion, it is not a constant temperature boiler
I am very curious about the legal part—how is an outdoor temperature sensor supposed to turn a condensing boiler into one that qualifies as low-temperature?
And only these two technologies are currently excluded. By the way, the law itself does not mention constant temperature boilers that fall under the 30-year requirement.
Incidentally, replacing the boiler is not the whole story. In almost every case, the chimney must also be modified when switching to low-temperature operation.
Mizit
27 Mar 2018 20:42
Big question marks are floating over my head ...
