ᐅ Energy Saving Regulation 2016 / KFW55 Standard / Gas and Solar in 2016
Created on: 1 Dec 2015 20:37
Grym
I have a question regarding the 2016 energy saving regulation. It is often stated that the transmission heat loss is reduced by 20 percent, but I cannot find this figure, unlike the change in primary energy demand, in the legal text. Instead, it says:
From January 1, 2016, the specific transmission heat loss related to the heat-transmitting building envelope of a new residential building must not exceed 1.0 times the corresponding value of the respective reference building.
Does this actually mean that these reference values have not applied before and only became valid from January 2016? Is the 20-percent tightening only implicit or calculated?
Furthermore, the KFW55 standard is based on these reference values concerning transmission heat loss. KFW55 corresponds to 70 percent, so is KFW55 about 30 percent stricter than the 2016 energy saving regulation regarding this parameter?
This is also suggested by the simplified benchmark values for KFW55, e.g., thermal bridge allowance 0.05 x 0.7 = 0.035 or 0.28 x 0.7 = 0.2. “Simplified” is relative, as you still have to calculate all thermal bridges.
Then the equation that KFW70 is roughly equivalent to the 2016 energy saving regulation is definitely not correct. KFW70 is at 85 percent of the reference values, while the 2016 energy saving regulation refers to 100 percent of the reference values. Therefore, KFW70 is still 15 percent stricter regarding transmission heat loss than the new energy saving regulation. Only in comparison of primary energy are the values closer, where KFW70 demands 70 percent and the energy saving regulation a tightening by 25 percent, so 75 percent.
This brings us to gas plus solar in 2016. A KFW70 house exceeds both primary energy demand and transmission heat loss requirements of the 2016 energy saving regulation. If there were KFW70 houses with gas plus solar before, there will continue to be. The requirements of the Renewable Energies Heat Act are met by the system under point I. 1.) a) aa).
Any opinions? Corrections? Counterarguments? Theories? Other comments?
merlin83
1 Dec 2015 22:03
I don’t understand a thing... Fortunately, there are well-paid professionals who include every little detail (like windows, etc.) to figure out what is possible and what isn’t.
Goldi09111
15 May 2016 13:39
I’m bringing up this old topic again.
Can it be generally said that, according to the new energy saving regulations, building with gas heating and a mechanical ventilation system with heat recovery (without solar) is sufficient, or is that not enough?
T21150
15 May 2016 13:50
Goldi09111 schrieb:
Is it safe to say in general that under the new energy saving regulations you can build with gas and mechanical ventilation (without solar), or is that not sufficient?
No! You cannot say it like that. It is very likely that, despite all insulation, thermal solar will be required.
You must (!) have this calculated on a case-by-case basis.
MarcWen15 May 2016 18:19
We could have achieved Energy Efficiency House 55 only with gas plus solar and controlled residential ventilation with heat recovery.
T21150
15 May 2016 19:05
MarcWen schrieb:
We would have achieved Efficiency House 55 only with gas + solar and mechanical ventilation with heat recovery.
Same here. Just a thicker foundation slab and underfloor heating.
But the current energy-saving regulations have changed somewhat.
Also, like you, I have gas, solar, and mechanical ventilation with heat recovery. Everything essential is already included.
Thorsten
Goldi09111
15 May 2016 20:06
I am not concerned with KfW 55, but rather whether it is allowed to build at all without solar panels but with controlled residential ventilation with heat recovery.
