ᐅ Programming heating settings for nighttime hours
Created on: 15 Mar 2018 22:50
Mizit
we have a somewhat complex problem and are currently unsure about what to do. Any experiences would be appreciated.
Our house is 23 years old, with a Buderus boiler and control system; the burner was recently replaced. In our living room, there was a kind of "thermostat" that was already broken when we bought the house. We naïvely accepted the sales advisor’s statement that it wasn’t needed and assumed that the heating could be controlled directly at the unit downstairs.
We suspect that something was set up about 23 years ago, after which no one cared about this thermostat, and eventually, it just broke. The water may be a bit cooler, and our bathroom radiator never really gets warm despite bleeding and unblocking. Otherwise, everything is fine for us. When my husband goes into the living room around 7 a.m., it’s still a bit cool, but absolutely okay, and when I come home in the afternoon, it’s warm in there. So far, so good.
Now, we have rented out our granny flat to a young woman for 8 weeks. There is only one heating circuit. Due to her work, she gets up at 4:30 a.m. This was not a problem before, but since last weekend it seems that the flat is freezing cold when she gets up in the morning. Previously, according to her, this was different, and the heating was running in the morning. Now it isn’t anymore. She feels cold and wants this changed, which I can understand.
Today, a technician was here. The problem is: this control unit is broken. The heating is set to something, the sensor is located outside on the north side, but exactly what was set can no longer be read or changed.
The young woman now wants the heating to be set so that it is warm at 4:30 a.m.
Because we have only one circuit, we cannot separate the systems for the granny flat and the main house. This means we would have to set it so that the radiators start heating at 4:30 a.m. for ourselves as well. This makes no sense for us—no one here gets up before 6:30 a.m., the children get up about an hour later, and we may not be as sensitive to cold.
But to do this at all, a new controller is needed. These parts from 25 years ago are no longer available today—you can get “refurbished” ones from various online shops for around 300 euros, but whether we can still set those ourselves is questionable.
The alternative would be a completely new heating control system, which would cost about 1500 euros; a binding offer will be made. That is certainly even more expensive 🙂
For us personally, everything is basically fine, so this is a lot of money. On the other hand, it may also not be very sensible if you have no way to adjust your own heating, and sooner or later, one might have to invest in this anyway?
Mizit
5 Apr 2018 21:39
Just a quick message from on the go, I will reply more thoroughly with a photo over the weekend:
The tenant is asking if it's possible to split one heating circuit into two separate heating circuits?
I've found varying information about this. I've read multiple times that it is "quite difficult" and better to have it measured with a system like Techem or similar heat meters with small tubes.
However, I’ve also come across posts that seemed to suggest it is technically easy to implement? I couldn't find any information about the potential costs anywhere.
Mycraft5 Apr 2018 21:47
Yes, of course it is possible, but you will need a separate regulation for that as well.
Mizit
6 Apr 2018 01:10
So, two new control panels? 🙂
Mycraft6 Apr 2018 07:14
No, usually one controller and two room thermostats are enough. So, however you look at it, you can’t avoid having a control system for your existing setup.
Mizit
6 Apr 2018 07:43
And how do the pipes then know that there are now two separate circuits?
Mycraft6 Apr 2018 07:46
Which pipes are you referring to?
