Hello, our slab foundation will be poured starting mid-March (single-family house without a basement). While daytime temperatures are unlikely to drop below 5°C (41°F), nighttime temperatures are currently expected to be around -2°C (28°F), according to the weather forecast. Is this a problem? What should I ask the foundation contractor to pay attention to (he is also under some time pressure because the house needs to be erected by the end of March)?
T21150 schrieb:
Hi,
at these temperatures, you first need to be able to have concrete delivered at all.
When it is delivered, you will receive winter concrete. This contains certain additives that account for weather conditions. There are various mixes with specific handling instructions and requirements. This is *not* a disadvantage; the concrete quality is always excellent.
Based on these mixture specifications, your groundworks contractor must work accordingly (or delay the work if conditions are not suitable).
A good groundworks contractor knows this really well.
Thorsten These additives usually involve an increased cement content. Furthermore, the concrete must not be exposed to temperatures below 10°C (50°F) for 3 days, otherwise the concrete or its structure can be damaged.
Baustelle201614 Mar 2016 23:15So, the work starts on Thursday... Then it should stay frost-free at night at first, and above 10°C (50°F) during the day. Exciting...
Baustelle201623 Mar 2016 07:53The foundation slab is in place. There was no frost. Starting Tuesday, the house will be built on it.
Baustelle201629 Mar 2016 23:43The ground floor is complete...
Baustelle2016 schrieb:
The ground floor is up... A positive interim report, congratulations.
Wishing you continued smooth progress with the construction
Thorsten
Baustelle20161 Apr 2016 11:05It is a wooden house, timber frame construction with log plank exterior walls on top. The shell has been standing since last night. Everything seems to have gone well.
