ᐅ Possible House Purchase – Air-to-Water Heat Pump Could Become a Money Pit
Created on: 15 Jun 2017 19:31
Chris1982_1
Hello experts.
A house that was built solidly three years ago (without insulation) is up for sale.
The house is equipped with an air-to-water heat pump as well as a fireplace. There are no solar thermal or photovoltaic systems.
Heating is provided by the air heat pump and the fireplace, and an energy performance certificate is available. The values have varied somewhat over the three years, but well.
The seller gave me the invoice for the heat pump and the underfloor heating yesterday.
How can I tell if this is a "good" energy concept?
Before I buy, I want to make sure I’m not getting into a money pit.
Do I possibly need the exact external wall thickness (which type of masonry), roof insulation, window specifications, etc. for that?
I would appreciate any information. Have a nice evening and best regards, Chris
Nafetsm17 Jun 2017 00:02
I’m so glad we went with gas. Just for comparison: same wall construction, 200sqm (2,150 sq ft) of heated space = 50€ per month.
Air-to-water heat pumps that are poorly configured are basically hidden electric heaters, and when properly set up, they are the biggest ecological myth in the industry.
You can buy a house, but the risk is that the underfloor heating, as already mentioned here, was installed poorly. You can adjust the pump, and there’s probably still some improvement possible. The question is how much... above all, you need to have the patience to learn how it all works. Heating curve, flow temperature, and a lot of patience will then be your best friends.
Joedreck
17 Jun 2017 08:05
You also need to adjust the heating curve and flow temperature for efficient gas heating.
There is nothing more to add.
Chris1982_1
17 Jun 2017 09:29
Thank you all.
The real estate agent says that this electricity bill includes both the heating costs and the hot water costs. So, the total wouldn’t be that high :-)
I need to take a closer look at everything.
Incorrectly installed underfloor heating: How can I check this? Is it even possible?
Nordlys
17 Jun 2017 09:35
No. Since it’s under the screed, incorrect installation just means the loops could be spaced closer together. If there are larger gaps, the heating system will simply need to work a bit harder. That’s not a problem, it just uses more energy.
The question is, since you’re focusing so much on the technical details like a typical man, does the house otherwise meet your expectations in price, location, and features? Then this heating system is just the compromise you have to accept. The wall construction is up to date. Karsten
Joedreck
17 Jun 2017 09:45
Sorry, but incorrectly installed would mean the spacing is too wide. This means the heat pump has to provide a higher supply temperature, and heat pumps operate extremely inefficiently under these conditions. Fixing this would require significant effort.
Hot water is only an excuse if the system has a circulation loop that provides 60°C (140°F) hot water 24/7.
Alex85
17 Jun 2017 10:05
Maintenance contracts that include settings adjustments and fine-tuning can be arranged for heat pumps just as for gas heating systems. Alternatively, you can have a professional come once to perform these tasks (if the company that installed the system does not have the necessary expertise).
There is no need to devote more or less time to maintenance than with other heating types. However, it is advisable to choose a skilled trades company whose professional training did not end at a master trade school 40 years ago.
