ᐅ LWW, Gas, or Geothermal Operating Cost Experiences
Created on: 19 Feb 2017 19:41
G-Star1988
G-Star1988
19 Feb 2017 19:41
Hey everyone,
We are currently planning our small house and are facing the big question of which type of heating system to choose.
Gas heating + domestic hot water
Heat pump (air-to-water)
Geothermal energy
I have researched the different types extensively. It is also clear that the initial investment costs vary.
Which heating system is the most cost-effective in terms of operating expenses?
Here are a few key details:
KfW-55 standard
About 140m² (1,500 sq ft)
Controlled ventilation system
Underfloor heating on ground floor and upper floor
Thank you very much for your advice
Invi8520 Feb 2017 06:51
when it comes to ongoing operating costs, I would definitely recommend geothermal energy.
We built our house last year, also using geothermal heating, and have just completed our first winter. I record the daily electricity consumption and the heat output, and compare these in an Excel spreadsheet.
During periods when temperatures dropped as low as -14°C (7°F), our consumption was between 20 and 25 kWh per day. At 17 cents per kWh, that comes to between €3.40 and €4.25.
Now that outside temperatures are between 0°C and 10°C (32°F and 50°F), consumption has dropped to between 9 and 16 kWh per day. I don’t think you can get much cheaper heating during winter.
The annual performance factor (Seasonal Coefficient of Performance) ranges between 3.93 and 4.27.
Our key specifications:
KfW55 standard
170 m² (1,830 sq ft)
Mechanical ventilation with heat recovery
Underfloor heating on ground and upper floors
Michael
G-Star1988
22 Feb 2017 11:04
Thank you for your figures. Does anyone else have comparison values for air-to-water heat pumps and gas?
I now have a concrete offer for our house, where basically the only decision left is which heating system to choose (and whether to go with brick cladding or not, but I can handle that myself).
Gas including solar included
Air-to-water heat pump around €3,500 (about $3,700)
Geothermal heat pump around €13,000 (about $13,700)
Invi8522 Feb 2017 11:19
No problem, but I don’t quite understand your offer.
Gas including solar and also heat pump for 3500€? Why combine gas and heat pump?
Regards,
Michael
G-Star1988
22 Feb 2017 11:21
No, sorry, that means 1 item per paragraph.
So
- Gas is included in my offer
- Heat pump 3500€ (instead of gas)
- Geothermal energy 13000€ (instead of gas)
Invi8522 Feb 2017 11:35
Take a look at the available funding options, as you can deduct these from the relevant costs.
Last week, we received our grant of 5,000€ (about 5,450 US dollars) for the ground-source heat pump. I believe the subsidies for air-to-water heat pumps are significantly lower.
