ᐅ Possible House Purchase – Air-to-Water Heat Pump Could Become a Money Pit
Created on: 15 Jun 2017 19:31
Chris1982_1
Hello experts.
A house that was built solidly three years ago (without insulation) is up for sale.
The house is equipped with an air-to-water heat pump as well as a fireplace. There are no solar thermal or photovoltaic systems.
Heating is provided by the air heat pump and the fireplace, and an energy performance certificate is available. The values have varied somewhat over the three years, but well.
The seller gave me the invoice for the heat pump and the underfloor heating yesterday.
How can I tell if this is a "good" energy concept?
Before I buy, I want to make sure I’m not getting into a money pit.
Do I possibly need the exact external wall thickness (which type of masonry), roof insulation, window specifications, etc. for that?
I would appreciate any information. Have a nice evening and best regards, Chris
Nordlys
15 Jun 2017 21:06
No. If the controlled residential ventilation system had cost another 10 with such a unit and you then saved twenty euros in electricity per month, it would have to run for a very long time. The technology is more likely to break down before that becomes worthwhile. Karsten
Chris1982_1
15 Jun 2017 21:07
Ok, so I would need to install a ventilation system as well? What is it necessary for? What are the benefits of the system? Less energy consumption?
tomtom7915 Jun 2017 21:09
@Nordlys Sometimes you really write nonsense.
Alex85
15 Jun 2017 21:10
Something doesn’t add up. €210 (about $230) for electricity per month—can that really be attributed to the heating? How large is the house? With €210 (about $230), you could easily heat a house using an electric space heater. That has nothing to do with a heat pump at all.
tomtom7915 Jun 2017 21:13
Air-to-water heat pump running at maximum output? Hot water set to 60°C (140°F) and airing out the space 3-4 times daily—then the electric heating element kicks in, and suddenly you have your 210 euros.
Joedreck
15 Jun 2017 21:16
A controlled mechanical ventilation system often does not make financial sense and is more of a "luxury." Manually ventilating is still necessary in new buildings due to the airtight envelope.
Regarding 2013, I assume the heat pump was very poorly adjusted. You would need to really get into the details there.
