baupfusch17 Aug 2013 17:31Hello,
we are currently building a KfW 60 house, 133 sqm (1,433 sq ft) living area, with 16 cm (6 inches) concrete walls, 12 cm (5 inches) of expanded polystyrene insulation, and underfloor heating on the ground floor. Upstairs, there is drywall construction with 160 mm (6 inches) glass wool insulation and radiators.
The developer wants to install a 6 kW air-to-water heat pump, since the plot is too small for geothermal energy.
A heating company currently working with us would definitely install a 9 kW inverter heat pump to cover cold winters. The developer believes that 9 kW is too large, even as an inverter device.
We now have to make a quick decision and would appreciate some advice on what system to choose.
There is a heat load calculation available, but it is reportedly still on the developer’s desk.
Thanks, baupfusch
Thanks, baupfusch
Furthermore, performance figures for air-source heat pumps, unlike other heat generators, are not very meaningful because heating capacity and COP can vary significantly with outdoor temperature.
Example:
Thanks, Baupfusch
baupfusch schrieb:The combination of underfloor heating and radiators is usually not very efficient. Especially if a heat pump is planned as the heat generator (HG).
...and underfloor heating downstairs. Above, drywall construction with 160mm (6.3 inches) insulation glass wool and radiators...
baupfusch schrieb:There is usually enough space for a vertical ground probe! ;-)
... The developer wants to install a 6 kW air-to-water heat pump. The plot is too small for geothermal energy...
baupfusch schrieb:This already disqualifies a candidate ;-) A heat load calculation kept in a desk drawer is of little use, especially since they are often incorrect.
... There is apparently a heat calculation, but it’s with the developer in a desk drawer.
Example:
Thanks, Baupfusch
