ᐅ My Kallax unit was decorated with glitter by children—how can I remove it?
Created on: 24 Sep 2017 18:27
dojaus
dojaus
24 Sep 2017 18:27
I unfortunately had a little accident with my Kallax shelf from IKEA. Apparently, my children had a lot of fun decorating some of the white surfaces with glitter – quite thoroughly, actually. Now I want to remove the glitter as completely as possible without damaging or scratching the surface of the Kallax. The surfaces are coated with a film, not painted, if that is relevant.
I have already considered using alcohol, adhesive remover, and even nail polish remover, but I am unsure what I can safely use without damaging the shelf. Does anyone have experience or tips on how to best remove glitter – especially sticky or firmly attached glitter particles? Suggestions for reliable home remedies or special cleaners are also welcome.
Thank you in advance for your help!
meole
24 Sep 2017 19:04
dojaus schrieb:
I have already thought about alcohol, adhesive remover, and even nail polish remover
I completely understand how frustrating that is, especially when kids are working with glitter – it sticks almost everywhere! 🙂
From my own experience, I would start with warm soapy water and a soft cloth to see if the glitter loosens a bit. If that’s not enough, I’ve had good results with very gentle rubbing using a mild nail polish remover (with acetone), but be sure to test it on an inconspicuous area first, as it can damage the surface.
Sometimes a little oil – for example, baby oil or even olive oil – can help dissolve the adhesive so you can wipe off the glitter particles more easily. Just make sure to clean the oil off thoroughly afterwards with dish soap, or it will stay greasy.
Patience and gentle handling are important here; scraping or aggressive cleaning would make me nervous. Hopefully, this helps you a bit.
susar
25 Sep 2017 08:53
meole schrieb:
Sometimes a little oil helps – for example, baby oil or even olive oil
That’s brilliant! I recently had a similar situation with glitter on a smooth surface, and baby oil really made it easy to remove 🙂
I find that if you then wipe it with a damp cloth and maybe a mild dish soap, the result looks great again.
And don’t worry, even if it seems hopeless at first – with patience, you can often remove glitter better than with harsh chemicals. Don’t give up! 🙂
Laurence
26 Sep 2017 11:17
Hello dojaus,
I completely understand the issue and am happy to offer some background information.
As you mentioned, the Kallax has a laminated surface, which is more delicate than painted finishes. For this reason, I would advise against using strong solvents like acetone or pure adhesive removers. Nail polish remover may contain acetone, so test carefully first!
Start with mild methods, such as warm water with dish soap and a lint-free cloth. If there are adhesive residues, inexpensive cooking oil or baby oil works excellently. The oil dissolves the glue, and with a soft cloth and some patience, you can remove the glitter. Important: After treatment, thoroughly clean off the oil using warm soapy water to prevent any residue.
If the adhesive is especially stubborn, you can carefully test some isopropyl alcohol (rubbing alcohol) on a concealed edge. This is gentler than acetone and effective against adhesive residues. However, always test in hidden spots and do not leave it applied for too long.
Avoid abrasive tools and harsh chemicals, as these can dull or damage the white laminate.
If you have any further questions, feel free to ask. I wish you success and patience with the removal – you can do it! 🙂
